F/S: Civic Parts: D16Y8 - AC, Alternator, Clutch/Fly, Starter, TB; Si Header
D16Y8(EX) Throttle Body - off a 97 EX, complete with TPS and MAP sensor, pristine condition, $70
D series alternator - off a 99 EX, perfect, $50
D series starter motor - off a 99 EX - in great shape, $50
Civic A/C components:
-compressor - $60
-condensor - $50
-fan - $20
-receiver/dryer canister - $20
-all lines, except hardline on passenger side to the firewall - $25
-hardware - $5
OEM D16Y8 Flywheel - off a 99 EX, great condition, $35
OEM D16Y8 Clutch - pressure plate and disc off a 99 EX, disc has a lot of meat left on it, $35
OEM 99-00 Si header(exhaust manifold) - with heat shield, $60
OEM rear dampers(shocks) - fit 96-00 Civics(all), $25
OEM Rear LCA's - fit 96-00 Civics, $50
OEM springs - fit 92-00 Civics and 94-up Integras, $40
OEM shifter arm - $20
OEM Civic radiator fan - $20
Buyer pays shipping costs on all items, if applicable.
________________
All parts listed are from a 97 Civic EX, unless otherwise noted.
I'm in San Jose, Cali.
[Modified by inspyral, 9:00 PM 11/17/2002]
-compressor - $60
-condensor - $50
-fan - $20
-hardware - $5
________________
You have an iacv for the y8? I am in need of one i think. Drop me an email at milkschillin@hotmail.com if you have one.
Thanks
Steven
Thanks
Steven
You wouldnt happen to have the throttle cable bracket that bolts to the intake manifold and holds the throttle cable in position would you?
Hella weird request... but I need just the two A/C lines that run above the exhaust manifold (both suction & compression). Can ya just get me those?
I am interested in the Y8 flywheel, are you willing to ship it?
how much better is the si header than the stock D16Y8 header?
****....oh well thanx anywayz man ..i didn't think about it not fitting right on the d series engines
will you just sell me the map sensor with the bolts? how much? email me at dunan720@hotmail.com
inspyral
Apr 25, 2003 12:47 AM
inspyral
Mar 1, 2003 07:53 PM
inspyral
Mar 1, 2003 07:52 PM
inspyral
Dec 14, 2002 09:40 PM
inspyral
Nov 7, 2002 11:25 AM
