civic clutch slave cylinder leaking (solved)
Old May 17, 2015 | 10:07 AM
swizz977's Avatar
Default civic clutch slave cylinder leaking (solved)
ok i finished my transmissionon my 2000 civic but the clutch wont come back up on its own
the pin on the clutch slave cylinder came out and i put it back in but now when i press the clutch down it leaks from there
Old May 17, 2015 | 10:11 AM
swizz977's Avatar
Default re: civic clutch slave cylinder leaking (solved)
now te spring came off with another piece
Old May 17, 2015 | 10:16 AM
Oaken81's Avatar
Replace the slave cylinder and bleed the system. Check the master too to make sure its not leaking inside the vehicle also.
Old May 17, 2015 | 10:54 AM
swizz977's Avatar
i have to replace it? i just bleed it seems ok now
Old May 17, 2015 | 10:59 AM
Former User's Avatar
If it's fine, then do nothing. If it leaks again, replace it. Problem solved.
Old May 17, 2015 | 11:15 AM
swizz977's Avatar
oh i think it was leaking because it wasnt hooked on the the transmission plate thr i had to bleed it
Old May 18, 2015 | 12:01 PM
swizz977's Avatar
Default Re: civic clutch slave cylinder leaking (solved)
well for a new clutch the pedel feels pretty soft.. i guess ill try bleeding it again
Old May 18, 2015 | 12:03 PM
Normal for new stock clutch.
Old May 18, 2015 | 01:11 PM
swizz977's Avatar
yea i put the exedy replacement kit in.. so i was t expecting anything crazy but just feels softer then i can remember.. maby its all in my head ill bleed it again and report back
Old May 18, 2015 | 04:04 PM
swizz977's Avatar
feels like less pressure then stock
Old May 18, 2015 | 04:19 PM
So far, nothing you've written indicates a clutch issue. Post a video that convincingly reveals a clutch problem.
Old May 18, 2015 | 05:05 PM
swizz977's Avatar
well i bought the one man bleeder it feels a little better now thanks
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
majinx4
Jun 15, 2006 11:30 AM
Ri5e
10
Sep 22, 2004 05:36 AM
myhatchrips
Dec 5, 2003 07:21 AM
SikofFalln
Apr 25, 2003 02:49 PM
