f20b madness
Old May 15, 2015 | 05:05 PM
f20beme's Avatar
Default f20b madness
I have power every where i need in my distributor and all my sensors are good but still no spark i re soldered and shrinktubed my ecu harness where it was frayed by my ecu i tried it again but still no spark. There was a black mark on the outside of the ecu is my ecu fried? And could it stop my spark but still run everything else the same like it still turns over fine this is the last thing i can think of i have spent like 700 on parts since i had the spark issue just so sick and feel like taking it to a bloody scrapyard any advice is greatly appreciated.
Old May 16, 2015 | 11:47 AM
crazyluder87's Avatar
Default Re: f20b madness
Take the ecu cover off n take a look you'll know if it's burnt or post a picture on here
Old May 16, 2015 | 09:26 PM
f20beme's Avatar
I used a 97 auto ecu and there was still no spark it turned over fine. I dont really know what else it would be
Old May 17, 2015 | 06:01 PM
thirsk66's Avatar
Have you checked all fuses and grounds on your car? Stop throwing parts and money into this car of yours and just troubleshoot your issue until you figure out what it is that needs replacing. Here is what a burnt ECU looks like, take your cover off and inspect the computer itself for any burn marks or charred resistors:
Old May 22, 2015 | 05:15 PM
f20beme's Avatar
No the ecu has no char marks on the inside i have power to the three wires to my icm doesnt that mean my fuses and grounds are fine?
Old May 23, 2015 | 02:04 AM
thirsk66's Avatar
No matter what you should never rule out any of your fuses always check them and grounds to make sure its all good to go. Also check your coil for proper voltage.
Old May 23, 2015 | 03:43 AM
civicRturbo482's Avatar
What he said ^^^
SOHCammed
23
Feb 16, 2009 05:46 AM
h2point2
Oct 3, 2007 09:36 PM
fenix4o9
Jul 7, 2007 11:35 PM
richardo
Oct 6, 2004 01:29 PM
WCI
Nov 9, 2003 08:17 PM
