Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Canadian Civic SE, timing chain?
Old May 15, 2015 | 03:01 PM
jonyi27's Avatar
Default Canadian Civic SE, timing chain?
so im looking for the timing chain for my 2008 honda civic SE, it is a canadian car. it is close to 100k i was wondering, when should these timing chain be replaced, also i am looking for the parts but it keeps trying to correct me by thinking im saying SI...is there anything similar? like LX model...it is a Automatic...thank you!!
Old May 16, 2015 | 05:36 PM
97emsedan's Avatar
Default Re: Canadian Civic SE, timing chain?
Use the EX model trim for your queries.
Majestic says the chain Mfg part number is 14401-RNA-A01...cost in USD is $117.05.
Old May 16, 2015 | 05:39 PM
97emsedan's Avatar
Might not be the chain, could've the tensioners...
14510-RNA-A01...USD$32.43 each, x2 same number left and right...
Old May 16, 2015 | 06:28 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The timing chain does not require replacement under normal conditions. Only if the timing chain was stretched or worn, etc. (which was usually due to low oil levels, infrequent oil changes, oil pressure, etc.) would the timing chain require replacement.
Old May 17, 2015 | 04:02 PM
DaveSi677's Avatar
agreed with tech8 on this one!
under normal conditions you don't need to replace the chain.
95Sedan
Jun 28, 2013 09:03 AM
therobesons
Sep 3, 2007 09:49 AM
