Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Honda Accord Starting Issue
Old May 15, 2015 | 10:49 AM
Nick Effler's Avatar
Default 2007 Honda Accord Starting Issue
I have an 07 Honda accord EX 4cyc, that has this random starting issue. When you turn the ignition sometimes it will not start, then you turn the key a second time, sometimes it will start, sometimes you need to try again. This has been going on for YEARS, but has gradually been getting worse. At first it would happen maybe once every 6-9 months, now it seems like once or twice a week. I just took it to a mechanic and they were unable to diagnose what the problem was just said it could be starter, or maybe the ignition, but replacing either would just be a guess. Just curious if anyone else had a similar issue, or any suggestions on what I could try to figure out what might be wrong?
Old May 16, 2015 | 12:23 AM
afnan's Avatar
Default Re: 2007 Honda Accord Starting Issue
may be it takes time to prime fuel. Check fuel pressure
Old May 19, 2015 | 10:06 AM
4dbull's Avatar
From what information you have given, I would be inclined to suspect the ignition switch.To verify place a meter,on 20v scale,between the solenoid terminal(from switch) on the starter and a ground.Since it is an intermittent problem it may take several tries before it fails to show 12 volts at the solenoid terminal.If it shows voltage and still doesn't turn the engine over then I would suspect a defective starter.I hope this helps.
kv1
Honda Accord (2013 - 2015)
Aug 18, 2019 08:00 PM
Chris Hankins
Aug 20, 2012 06:05 AM
mexicanswateam
Mar 18, 2010 11:03 PM
mellophonium
Nov 5, 2008 04:56 PM
Mx3Kfze
Dec 31, 2004 04:54 AM
