Please help teggy fans
Old May 14, 2015 | 10:42 PM
Hawaiianhonda's Avatar
Default Please help teggy fans
Aloha everyone, so I have a 95 gsr with a JDM itr front end swap and I've had for about 6 months and everything was fine and I go to leave work and start it and I see a Lil fire starting from a fuse section of wiring. I assume its from the headlight re wire for the front end? Its weird cuz it was fine all this time. now, I have no running lights,back up lights,or license lights :'( so frickn irritating cuz its like midnightish and after my 2nd job, luckily I have hids so I could barely limp home
:'( any clues guys???
Old May 15, 2015 | 10:30 AM
cvcrcr99's Avatar
Default Re: Please help teggy fans
I would be surprised if someone here is able to pinpoint the issue with your current description. You have a wiring problem obviously. Did you do the swap, or did someone else?
Sounds like you need to go back through the wiring and fix any problems. I rewired/tucked my body harnesses in my 98 sedan (jdm front) with no problems.
Old May 18, 2015 | 07:45 AM
Ya everything was fine until recently. I'll check and get back to u guys. Aloha.
Old May 18, 2015 | 05:01 PM
So wen I test the 10 amp tail light,instrument light,license light fuse, the right side of it lights up my test light but if I touch the left side, theirs nothing, this is with the lights turned on......ways that mean?
Old May 22, 2015 | 09:18 PM
So I found that the illuminate wire for radio was not connected to my deck and basically grounded out on the frame. Lights and everything work now but all of a sudden, wen I lock my car, the side markers don't flash but if I use the blinkers, they work fine.........could it be the flasher relay ?
Old May 22, 2015 | 09:47 PM
bigjon1378's Avatar
WHAT THE **** IS A TEGGY!?
Old May 23, 2015 | 02:38 PM
cvcrcr99's Avatar
what are the side markers wired into? The corners? If so, do the corner blink when you lock the car?
Old May 25, 2015 | 03:39 PM
Yes the side marker/blinkers blink wen I lock the car but now, the passenger side marker/blinker don't flash wen I lock it but they flash if I turn on the hazards or put the blinker on left or right......
FYI, teggy is for integra! Everyone here knows that reference!
Also, the passenger city light and fog light don't work, bulbs are fine but no power to them, driver side lights up fine thou.....is their a passenger running light relay?
civiceagle2
Feb 6, 2012 11:56 AM
dorado_mike
Oct 21, 2010 11:36 PM
tyronne1126
Audio / Security / Video
Mar 17, 2010 10:39 PM
DelSeeYa
Jun 11, 2006 08:56 AM
TypeR 599
Jan 19, 2002 11:06 AM
