I have a 98 Civic that has an aftermarket HU and 4 kicker speakers, 2 in front and 2 in rear. Had a local shop install the head unit and I did the speakers. All of a sudden my driver side rear speaker stopped working. Took that speaker and hooked it up to passenger side rear wires and sound came out. I connected a working speaker to the driver side rear wires and there was no sound. Checked behind the HU and all connections seemed to be good. Took a multimeter to the rear driver side wires and got no reading. Then I took normal speaker wires and connected them to the driver side rear speaker and the + and - wires behind the HU and it worked, so I'm thinking that I have a short somewhere in either the + or - speaker wires that snake through the car. How can I determine where this short is coming from? Thank for any help.
Here is how the left rear speaker wires are routed:
Dashboard harness
radio C515 --> C503
Floor wire harness
C503 --> C562
Rear wire harness
C562 --> C603 left rear speaker
If you continuity test the left speaker wires (+ and -) contained in each wire harness (Dashboard, Floor, Rear), you may identify which wire section has the break. Then you only need to run a new wire for that section of wire.
Where do I place the multimeter probes to test continuity, would it be black the negative terminal and red to positive terminal in harness? What should reading be at? What pieces do I need to remove to access floor and rear terminals?
