97 Civic Ex crank NO START
To make a very long story short I had issues with my Y8 and I swapped it out for a Y7 and kept my Y8 intake. I was able to get it started once but not since.
Here are my CEL CODES: P1298, P1509, Also sometimes getting P0700 and p1759 which are ECU and linear solenoid. Do I need to swap ECU's to a Y7 ECU? I did have it started and running on a Y8 ECU... this guy needs a
Ron,
Probably did mean P1758. The IACV is plugged in. I read a thread before I posted this one and the guy was saying to ohm the IACV, which I did with my terrible Multimeter and results inconclusive... Will update when I test the Y7 ECU. Thank you
The linear solenoid is plugged in and the code returns only if i turn the ignition off and back on after clearing the codes. Yes, the fuel pump primes and shuts off. I am getting 40psi after the filter. When I turn the key on the CEL comes on, off for a half second and back on.
Check whether fuse 15 is blown (P1298).
Does your IACV connector have 2 or 3 wires (P1509)?
Make sure the IAT connector is plugged in (P0113).
Post pictures as part of your answers.
Fuse 15 was blown, good call. I have my battery light again! I am still missing my oil pressure light. My IACV is a 3 wire. Again you were right, the IAT sensor was unplugged so the car could "Breath." I don't have the ability to get pics from my phone to the PC, but I'm working on that.
I just retested my spark and the color seems to be more of a orange and blue. This test was done by sticking a screw driver into the wires and holding close to the valve cover. Is that the recommended way?
Does the starter crank the engine strongly with key in ON(III)?
