2007 TL type s
No, as long as the system has not logged a fault, there are 2 other ways to reset the unit..
- Press and release the Talk button.
After the beep, say ‘‘System.’’
The HFL response is, ‘‘System options are setup and clear.’’
After the beep, say ‘‘Clear.’’
The HFL response is, ‘‘This process will clear all paired
phones, clear all entries in the phonebook, and clear the
passcode. Is this what you would like to do?’’
After the beep, say ‘‘Yes.’’
The HFL response is ‘‘Preparing to clear all paired phones, all
phonebook entries, and the passcode. This may take up to 2
minutes to complete.’’
After the beep, say ‘‘OK’’ to proceed, or say ‘‘Go back’’ or ‘‘Cancel.’’
If you said ‘‘OK,’’ after a short period of time, the HFL
response is, ‘‘System has been cleared. Returning to the
main menu.’’
The other method of clearing the system is for models without navigation: Disconnect both battery cables from their terminals. Leave them disconnected from the battery for a few minutes. Then with the terminals still disconnected from the battery, let the positive and negative terminals make contact for 30 seconds. This will reset everything in the car so have radio codes ready and all seating/radio/ecu memory will be cleared. Finally, reconnect battery as you normally would .
If unsuccessful, then it needs to be cleared though HDS or GNA600 tool.
main menu.’’
