headers nut torque spec and procedure
Old May 11, 2015 | 09:36 PM
95gsr@530's Avatar
Default headers nut torque spec and procedure
Chilton and Mitchell1 are both not giving me anything for exhaust manifold to head nut torque specs. I'd imagine the order to torque em is from inside to out, as with most gasket'd pieces, I just don't want to over torque, knowing how much a pain in the *** these studs can be, and how brittle they can become. If anyone knows of a good place to look, or the actual specs, I would greatly appreciate it! thank you! google search just brought me to this forum where I have found no luck so far
Old May 12, 2015 | 10:40 AM
86azms3's Avatar
Default Re: headers nut torque spec and procedure
Look in FSM, but it should be about 23ftlbs.
Old May 12, 2015 | 03:13 PM
B_Swapped93's Avatar
that equates to "good hand tight" I've never seen anyone use a tq wrench mainly cause it's hard to even get a little 3/8th ratchet let alone a big tq wrench.
Old May 14, 2015 | 12:55 PM
EnjoyTheRideDC2's Avatar
Guess you've never heard of using an extension...
Old May 14, 2015 | 02:14 PM
Bit hard with an aftermarket full rad, and straight up not possible with a topmount/ramhorn manifold I should know I could barley get a box wrench on the top/bottom middle/ nuts of my ram. Sure this topic is N/A but extension have set sizes 3/6/12'' that I know of, yes I checked snap on.
Old May 15, 2015 | 12:44 AM
All that might be relevant if the OP was in a similar situation as you. At this point, I doubt a ramhorn manifold or oversized radiator is involved. I'll agree, I dont typically see people use torque wrenches when tightening exhaust manifold bolts. It has nothing to do with the inability to use one in the given amount of space.
There's enough room to access the bolts with a 6 inch extension, socket, and ratchet/torque wrench. An aftermarket dual row radiator with fans wont cause any issues. Its not like the header is pressed up against the radiator core
Snap-on offers extensions in various lengths : 1.5", 2", 3", 4", 6", 8", 11", 18", 24", 36". I dont even recall them offering a 12" extension. There's no small/medium/large set standard for extensions. Maybe your tools designate extension lengths using general size terms, but there is no industry standard in regards to the set length of a ratchet extension.
Old May 15, 2015 | 12:57 AM
There's enough room for a box end wrench to be used in this situation. Not for a ratchet and socket, but it's an exaggeration to say those bolts are hardly accessible with a box end wrench. What else is limiting you from getting a wrench in there?
EG-SIXV-TEC
Honda Civic (2001 - 2005)
Apr 7, 2009 07:32 PM
EG-SIXV-TEC
10
Apr 2, 2009 07:43 PM
smxcan
Jan 12, 2009 07:17 PM
