Honda Civic 2002 DX need help
2002 Honda Civic DX- 1.7L
Receiving several codes and would appreciate any help.
P1491, P1298, P1259, P0301, P0302, P0303, P0304
The car has about 160k on it. The timing belt has been replaced. It runs pretty good, sometimes takes a second to start.
P1491 Honda Exhaust Gas Recirculation Valve Insufficient Lift OBDII Engine Light Trouble Code | Engine-Codes.com
P1491 Honda - Exhaust Gas Recirculation Valve Insufficient Lift
P1298 Honda Electric Load Detector Circuit High Voltage OBDII Engine Light Trouble Code | Engine-Codes.com
P1298 Honda - Electric Load Detector Circuit High Voltage
P1259 Honda VTEC System Malfunction OBDII Engine Light Trouble Code | Engine-Codes.com
P1259 Honda - VTEC System Malfunction
P0301 Honda Cylinder Number 1 Misfire Detected OBDII Engine Light Trouble Code | Engine-Codes.com
P0301 Honda - Cylinder Number 1 Misfire Detected
P0302 Honda Cylinder Number 2 Misfire Detected OBDII Engine Light Trouble Code | Engine-Codes.com
P0302 Honda - Cylinder Number 2 Misfire Detected
P0303 Honda Cylinder 3 Misfire Detected OBDII Engine Light Trouble Code | Engine-Codes.com
P0303 Honda - Cylinder 3 Misfire Detected
P0304 Honda Cylinder Number 4 Misfire Detected OBDII Engine Light Trouble Code | Engine-Codes.com
P0304 Honda - Cylinder Number 4 Misfire Detected
you Sir, have serious engine problems to attend to !
quiambao1180
Dec 3, 2015 02:33 PM
