CV joint question
Old May 11, 2015 | 12:21 PM
bdr_one's Avatar
Default CV joint question
I have a 93 Accord and I was wondering if a cv joint can be bad and not have a clicking noise also can it lock up making the car feel like it's jerking at 2500 and 50mph and vibrate on acceleration. I know the left side had been replaced and look at the right doesn't look like it's ever been replaced. It kind of remind minds me of a bad caliper but the calipers and brakes are good on the car
Old May 11, 2015 | 04:13 PM
holmesnmanny's Avatar
Default Re: CV joint question
It's possible for the boot not to be torn and still be bad but it will make noises while driving. Over time, the grease inside does wear out and stop supporting the joint. We're talking about atleast 200k though.
Old May 11, 2015 | 04:57 PM
spoonfedcrx's Avatar
Vibration on acceleration is common symptom of a bad axle. If the front end is all tight I would look into the getting the axle replaced.
Old May 11, 2015 | 07:23 PM
bdr_one's Avatar
Yep it's got 215k on the right side looks like its never been replaced
Old May 12, 2015 | 04:41 AM
masospaghetti's Avatar
Vibration on acceleration, based on my experience and research, is a common symptom of a cheap, low quality aftermarket axle. You can read about what I went through here: https://honda-tech.com/honda-accord-...ation-3227179/
My advice to you: If you plan on keeping the car for awhile, the only replacement axle worth buying is a Raxle. They are not cheap, but they are actually made from high quality parts. Vibration problem was immediately cured. Twelve axles from 4 other sources all vibrated under acceleration. Think about how much wasted time that was - don't do it!
b20bFourDoorCivicLX
Dec 17, 2013 05:22 PM
Bush-15
May 26, 2009 09:46 AM
zero808
Mar 2, 2006 07:43 PM
LudeJdm
Jun 2, 2005 11:50 PM
GReddy SI
12
Jul 17, 2003 04:07 AM
