o2 sensor placement
Old May 10, 2015 | 11:35 PM
Efabe's Avatar
Default o2 sensor placement
97 accord f22b1. NA, cold air, header back ex, Ok heres my situation, when i installed my exhaust system, just about everything went together and lined up with the factory mounts like it should, except for the 02 sensor ports. My stock exhaust had em directly on both sides of the cat and the new system has the up stream sensor right in the manifold. i can probably re route some wires and make it work But Im thinkin that the stock ecu is going to over compensate for the surely higher voltages that the sensor will be sending from being that much closer to the motor.
Old May 11, 2015 | 03:50 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: o2 sensor placement
nope. you can put it anywhere between the cat and the head. the stock O2 isn't that accurate to begin with, it won't make any difference.
AuroraHonda
Sep 11, 2009 05:12 AM
DC2*Integra
Aug 25, 2005 06:21 AM
madman604
May 12, 2003 08:44 AM
