shift linkage bushing
Old May 8, 2015 | 06:35 PM
realistpnoy's Avatar
Default shift linkage bushing
I have a 2000 Honda Civic DX Hatchback Manual Transmission and there is a little gap between the bracket and the bushing which causes a play when I move it left and right, is this normal? Thanks.
heres a picture as an example
http://cimg3.ibsrv.net/cimg/www.hond...r-08-47235.jpg
Old May 8, 2015 | 06:56 PM
MattsLegit's Avatar
Default Re: shift linkage bushing
I'll look at mine tomorrow I thought their are washer on both sides.
Old May 8, 2015 | 07:41 PM
I just looked under my car, there is no space between the bracket and the bushing. Although between the BOLT(28) and COLLAR(19), there is a small movement if I push it up and down. Is this normal or there should be no play?
heres the diagram, also theres no washer
Old May 8, 2015 | 07:46 PM
Former User's Avatar
Car information is required. Add to first post.
Old May 10, 2015 | 10:46 PM
RestoRoc89's Avatar
I just replaced the bushings in my 2000 CX hatchback last night with Energy Suspension bushings. The new bushing was a very tight fit in that bracket. By the time I had torqued the bolt up, the ears were fully seated against the bushing sides. The joint feels darn near solid. There is little play between the bolt and the collar (though I installed a brand new OEM bolt with the kit). The factory torque spec is 16 lb-ft. Have you checked that the bolt is fully tightened?
MMMGIRL
Jun 20, 2012 04:58 PM
racingcrx
Mar 24, 2008 10:51 AM
Panda hatch
11
Jul 26, 2007 06:55 PM
many styles
Nov 26, 2005 06:57 AM
SOHC_MShue
Jun 12, 2003 04:43 PM
