Throttle Body gasket
Old May 8, 2015 | 06:37 AM
egsleepercivic's Avatar
Default Throttle Body gasket
Motor Info
1993 JDM b16a, Throttle body uses firewall mounted map sensor
Does anybody know if the throttle body gasket is different for a throttle body with a firewall mounted map sensor vs. one with a throttle body map sensor
I am looking at getting 16176-P30-004, from a 1995 Del Sol Vtec
or should I get 16176-PR4-004, from a 93 GSR
not sure if the 93 gsr has a Firewall mounted map or not.
The reason I need it is because my throttle body is sticking a little and not smooth and I need to remove it and clean it
or if there is another model b series I should order for lmk
TIA
Old May 8, 2015 | 06:44 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Throttle Body gasket
Take your tb off and take it to autozone or advanced auto.
Old May 8, 2015 | 08:50 AM
yeah, no doubt I could do that, but thats not what I wanna do, also I will using a honda gasket.
Old May 8, 2015 | 11:53 PM
Ferio Wdm Edition
Doesnt matter what gasket brand to use. Felpro is a damn good brand.
Old May 9, 2015 | 11:21 AM
EsotericImage's Avatar
Retired Moderator
Id use a P2R gasket... And doesnt matter about the map. This gasket goes from TB to intake manifold.
90_civic_Si
Nov 28, 2009 09:11 AM
patrick4588
Engine Management and Tuning
Aug 9, 2008 05:20 PM
maximedx
Aug 17, 2007 02:11 AM
unabonger
Jan 26, 2003 09:58 PM
MugenizedR
Nov 18, 2002 02:50 AM
