Depin SRS plugs
Old May 8, 2015 | 06:09 AM
PR8urVtec's Avatar
Default Depin SRS plugs
Does anyone know how to depin the SRS plugs? I have been trying to get it done with some welding wire but I just can't figure it out. IT's the plug that hooks the airbag up to the wiring harness to the car.
Thanks
Old May 10, 2015 | 03:36 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Depin SRS plugs
Post a pic
Old May 11, 2015 | 10:38 AM
PR8urVtec's Avatar
I ended up cutting and soldering the new plug I need. Everything worked out fine. SRS is working fine now.
Old Oct 25, 2024 | 04:53 PM
Tankbyu's Avatar
Thanks
I have the same question. Someone cut the wires to the SRS reset plug and I want to re-connect the wires like stock. I have depinning tools. Pictures attached.
This is the end the wires were cut from.
Old Oct 26, 2024 | 08:53 PM
Tankbyu's Avatar
I figured it out with the help of a magnifying glass. There is a plastic tab that has to be pryed downward. You can see the tab in the pictures below and also where it clips into the pin.
Dr_potatohead
Dec 29, 2014 03:48 PM
loki2323
Audio / Security / Video
Sep 6, 2005 07:52 AM
GripFactoR
Nov 21, 2003 02:36 PM
