F22B1 to F22A?
Old May 7, 2015 | 03:08 PM
AudioFunk's Avatar
Default F22B1 to F22A?
My buddies dads 94 Accord EX with about 300k blew a head gasket and the coolant got into the oil, we found a JDM F22 Non VTEC for cheap and I was wondering if we can swap that in place of the VTEC engine? Can we also use the same transmission? (automatic) Do we have to get a new ECU? or can we use the F22B one? Might have a CEL for the VTEC, but would it work? Thanks in advance.
Old May 7, 2015 | 04:19 PM
GhostAccord's Avatar
Default Re: F22B1 to F22A?
You will need the Non VTEC (F22B2-P0B) ECU if you want it to run. One from a 94/95 non VTEC Automatic Accord would work.
You will also need the F22A intake and exhaust manifolds. Keep your F22B1 distributor.
Old May 7, 2015 | 06:34 PM
AudioFunk's Avatar
Thank you. Transmission should bolt right up right?
Old May 7, 2015 | 07:16 PM
AudioFunk's Avatar
The F22B Non VTEC also came in the Odyssey and I found a AT ECU would that one work also?
Old May 7, 2015 | 07:29 PM
MAD_MIKE's Avatar
MM Gruppe B
F22B6 is the Ody engine. Similar to the B2 but with a power band closer to that of the B1 during VTEC operation. But it is down 5HP and up 5torque. If your car is an AT then using the AT ECU will be no problem.
Spookythescary
Mar 30, 2018 11:18 PM
Fireman.142
Dec 10, 2010 06:19 PM
souljah07
May 31, 2007 07:27 AM
jagged4698
Jan 25, 2004 06:09 PM
