95 honda accord clutch bleeding
Old May 4, 2015 | 09:22 AM
danielb4200's Avatar
Default 95 honda accord clutch bleeding
So i had a bad seal on the cap for my clutch master cylinder so i replaced it and bleed it. I have petal now to where i can drive it but the sometimes the petal still goes to the floor. What could be wrong now? I really need some help with this. Any advice will help.
Old May 4, 2015 | 10:21 AM
holmesnmanny's Avatar
Default Re: 95 honda accord clutch bleeding
You either got a bubble in the system, which is likely, or the master cylinder is bad. It's more likely you have an air bubble.
Try bleeding it and before you start bleeding, have someone rapidly pump the clutch, while you squeeze the rubber reservoir hose up and down with the cap open and look for air bubbles raising up through the reservoir. Sometimes air bubbles get stuck in there.
Old May 4, 2015 | 01:48 PM
djkurious's Avatar
Also, check for clutch travel in the service manual.
Valenciabrihh
Transmission & Drivetrain
Dec 29, 2014 05:25 PM
cd5jdm96
Sep 15, 2013 10:14 AM
cleansi
Aug 13, 2012 05:21 PM
accord23
Nov 15, 2006 04:43 AM
AccordEx1995
Jun 15, 2004 04:24 PM
