Mega Gloss Polyurethane Enamel on carbonfiber
anyone used this roll on marine clearcoat? or does anyone knows of a good roll on epoxy clear
i need to fix my faded cf hood.
You can use a number of products. Two of which are from Home Depot. Super glaze two part epoxy and rust oleum epoxy floor coating. They work well.
Rust oleum needs to be applied with a squeegee and slightly cut with Mek or thinner. Ith can be sprayed with a pressure pot. Works extremely well as it is chemically just an aliphatic resin used to coat cement.
Super glaze will self level and must also be squeegeed. It is used for table tops.
I would not roll on a finish. Squeegee a self leveler or spray.
Sassafrass
Feb 2, 2004 05:23 PM
