Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2006 ODY help... Alternator removal
Old May 1, 2015 | 12:10 PM
D0661E750's Avatar
Default 2006 ODY help... Alternator removal
Got the 2 bolts out and I don't know how to remove the alternator. There is no room. Should I take off the radiator?
Old May 1, 2015 | 03:35 PM
sytntyt's Avatar
Default Re: 2006 ODY help... Alternator removal
remove the p/s reservoir from its holder. remove the 10mm bolt holding the a/c suction line to the bracket. remove the washer tank bolt. bend ever so lightly the suction hose towards the radiator and it should pass with barely any room to the left.
Old May 1, 2015 | 04:48 PM
D0661E750's Avatar
Thanks Synth: I didn't get to read your reply on time but I was able to take IT out by an alternative approach, stated below:
1-disconnect the batt
2- remove intake and engine top covers
3-dislodge serpentine belt
4- dislodge washer reservoir by removing 3 bolts (no need to remove the washer housing)
5- remove 2 engine mount bolts, located near bottom part of computer module
6- lift the engine about 2-3 engine.
Remove alternator...
Tight path, requires perfect touch, rear side outward. Rotate about 20x.
Cheers!!!
aemintgsr
Acura TL, RL & ZDX
Nov 18, 2013 06:36 AM
TnC
Jan 27, 2011 12:13 PM
djrico724
Aug 10, 2008 09:42 PM
Jeff
14
Oct 19, 2005 12:02 AM
ch4nq
18
Jul 26, 2004 01:59 AM
