the best parts ad mid atlantic classifieds has seen in years TONS OF NICE PARTS!
UPDATE:
all parts are OBO best offer but please no lowballing
all parts are PICK UP ONLY in dundalk md 21222. so that means you must come to me to pick up parts
I can ship if you have paypal and pay shipping
PICTURES AVAILABLE UPON REQUEST. I wasn't going to upload 200 pics to this ad just message me for pictures please
Parts:
-JDM ITR engine / long block. No trans only 14,000km. From hmotorsonline.com
-JDM gsr head. Fresh out of machine shop missing valve cover and dizzy
-b16a2 complete head off 2000 civic si. Missing valve cover and dizzy
-custom powder coated bseries vtec valve cover with catch fittings and lines and catch can
-obd1 gsr vtec dizzy
-GSR crank perfect shape
-Gsr block girdle
-16" slipstream style wheels with 225 Toyo tires in front like new 4x100. All tires fresh all time fresh no curb
-precision 1000cc low imp injectors obd1 clips only used with pump gas. Made high HP with turbo car. They work 100%. Comes with resistor box
-clutch masters 6 puck unspring clutch and flywheel kit used
- omni 4 bar map sensor
- manual boost controller blue in color
-aem short ram intake for 2000 civic si used
-innovative billet motor mounts for 96-00 civic billet polished with red bushing set of 3 retail on innovative site is 300$ these are only used for 1000 miles good shape can be used with b or d
-hasport billet mounts for 96-00
Complete set always been the best mounts on the market. Only used for a few months Can be used with b or d
-JDM integra 4 door type r doors. Bought from jdm importer still has oem type r decals on rear doors white in color panels are mint condition window switch is on opposite side for rhd real type r 4 doors
-4 door integra side skirts white in color
-4 door integra rear bumper white in color
(both came with the doors and the front end so I am assuming they are off a 4 door integra type r as well)
-brand new in box injen intake for 97-01 integra type r but will fit any 94-01 integra I believe
-Oem bseries stock jdm type r fuel rail and injectors removed from a jdm itr with 14,000 km
-Jdm type r intake manifold complete with aftermarket throttle body rest all
Oem parts and fresh
-bbk aftermarket throttle body 62mm has both tps and map sensors on it
-bseries half shaft for use with any bseries engine I HAVE 2 OF THESE
-bseries tbracket for eg/dc
-bseries tbracket for 2000 civic si
-post mount for 2000 civic si
-trans mount bracket NOT MOUNT for 2000 civic si
-brand new oem Honda integra hood latch
-p30 power steering pump obd1 bseries no brackets
-type r power steering pump and brackets and reservoir came on a obd2 jdm itr swap I believe it's a p72 sticker on the pump
-99-00 civic si complete stock engine mounts and 2 torque mounts
-99-00 civic si power steering pump and bottomn bracket top was cut for turbo
-99-00 civic si ac bracket
-99-00 em1 oem si front upper control arms
-99-00 civic si em1 brake master cylinder and brake booster
-99-00 civic si em1 complete sunroof setup with slider
-JDM ITR rear sway bar. i have 2 of these
-JDM ITR front sway bar
-moroso catch can with single -10 inlet single filter up top and drain down bottomn
-2 bseries tapped oil pans for turbo drain
-exedy stage one bseries clutch and pp and flywheel only 1000 miles still like new
-integra Air conditioning setup removed from a car with working air condition some of the stuff was new replaced oem Honda but it looks like its everything the lines the compressor the condenser etc
-stock 2000 civic si radiator I have 3 of these one with slim fan
-brand new slim fan
-2000 civic si ac setup removed everything from working car
-2000 civic si engine wire harness some clips cut that weren't needed for gsr / lsvtec
-96-98 civic wire harness wired for bseries vtec jdm gsr swap
-purple password jdm ****
-skunk 2 weighted ****
-avid aftermarket billet polished rear motor mount with a halfway torn bushing. still usable can get bushing on ebay for cheap
-custom made backdoor intercooler turbo side is backdoor the other side is normal side entrance painted black not sure of dimensions but its 500hp+ capable its not huge by any means but it works
-big no name brand front mount 2.5 in and out. In ok shape. One side was Paint black
-96-00 civic dseries shift linkage
-Dseries linkage energy suspension bushings 2 packs both brand new each comes with both bushing needed
-obd1 po6 5speed ecu can be used for hondata
-obd2 type r ecu p73 5speed
-2 Oem bseries flywheel both used
-Oem bseries header b16a2 99-00 civic si no heat shield
-96-00 stock exhaust midpipe
-96-00 civic coupe black manual mirrors and power mirrors
-3" custom 94-01 integra exhaust downpipe back to muffler flowmaster vibrant style muffler 3" cat 3" resonator 3" flex perfect setup for any turbo car does have downpipe welded to midpipe
-2.5" exhaust midpipe back to muffler can style muffler was on a 2000 civic ex 4 door looks new
-autometer pro comp oil temp gauge
-autometer lunar series oil pressure gauge
-2 gauge a pillar pod have 2 of these
-gm 3bar map just sensor no wiring plug
-apexi boost contoller avcr used was removed from the car with all wiring but no boost sensor just will have to read diagram online on how to wire to your own car
-2 sets of 96-00 civic front seats and one set of rear seats. one set is out of 00 ex coupe one set is out of 98 hx coupe
-96-00 civic door black some stuff has been sold off paint is fresh black power but can be used power or manual like any honda door
also have 4 parts cars 2 are 96-00 civic coupes and the other is 1999 4 door civic and the last is 1995 4door Integra so I have a ton of random parts bolts brackets nuts plastics and little misc stuff. a bunch of random interior plastics etc.
Parts:
-Gsr block girdle
Oem parts and fresh
-brand new slim fan
i have new oem style ones used but not for long i have a bracket for the trans with the mount already attached just need to maybe dig for the bolts unless you have some i have a huge bolt bin everything gets thrown in for the driver side the torque mount bracket is the ac compressor bracket do you have that you just need the mount or what?
I have everything for climate control but the black outer bezel plastic Only sunroof I have is 99-00 civic si
Teins are sold
I will take 140$ for the torque brackets (ac bracket and trams) and the engine mounts
I would take 250$ for rad and fan. Itr cable I had I believe sold and no washers at the moment
Was away on vacation. Just got back sorry for delay. Also need to update the ad. Some stuff sold and some new stuff has arrived. So please bare with me if you ask for stuff and it has been sold. Need to clean up the ad
inbox cleared sorry guys was on vacation and havent been on in few weeks
Pics of this?
14” steelies 4x100 with newer tires rims are painted white
also, what tires?
also, what tires?
Bump front end still available unfortunately. The offers keep getting lower and lower
And no I don't have a way to send a pic measuring them . But they are 23mm i am 99.9 sure
