Accord 1993 ex stops at lights
Old Apr 30, 2015 | 10:32 AM
AlexV's Avatar
Default Accord 1993 ex stops at lights
Hi all. I've researched the forums and found some stuff but the problem persists. When I stop at the lights , my rpms go down to 500 and the car shuts down. Doesn't happen always. I starts right back normally. I've tightened fast idle and cleaned the iacv. Same thing happened this morning. Do you have an idea what it could be? Thank you for your help I really appreciate you guys
Old Apr 30, 2015 | 11:50 AM
holmesnmanny's Avatar
Default Re: Accord 1993 ex stops at lights
Its possible you have a lazy oxygen sensor. If it hasnt been changed in over 75k or so it would be wise to swap it out with only a Denso unit.
Old Apr 30, 2015 | 12:08 PM
AlexV's Avatar
There are 2 types right? Upstream and downstream. Should I replace both?
smooz EK
Oct 12, 2016 10:19 AM
1yesfan
Dec 13, 2015 12:47 PM
dasjestyr@gmail.com
Feb 23, 2009 11:29 AM
