Transmission & Drivetrain Gearboxes, Differentials, Clutches
Integra GSR 95 B18C1
Old Apr 28, 2015 | 05:30 AM
wonderingpanda's Avatar
Icon2 Integra GSR 95 B18C1
when is turned i can put the car into gear without using the clutch an it slides in perfectly, iv changed the cv axles, pressure plate, clutch, an the master clutch was replaced a little less than a year ago. i cant seem to figure out why it can go into gear without the clutch.
Old Apr 28, 2015 | 02:26 PM
94EG8's Avatar
Seagull Management
Default Re: Integra GSR 95 B18C1
As in you can put it in gear and the car wont move?
Either a one or both of the CV axles is not seated in the differential, or you have some serious internal transmission damage. Usually it's an axle not seated all the way. If the speedometer moves in gear with the clutch out look at the axles, if it doesn't pulled the trans apart.
Old Apr 30, 2015 | 04:57 AM
as in i can have the car running an put it into gear without using the clutch an it doesnt even grind when its going into gear and the car wont move forward in 1-5 an doesnt go backwards when in reverse. but it slides into each gear perfectly.
Old Apr 30, 2015 | 06:42 AM
also if i were to push the clutch in an put it into gear an release the clutch while in gear without any gas the car doesnt stall out.
Old Apr 30, 2015 | 01:17 PM
94EG8's Avatar
Seagull Management
As I said before if the speedo moves in gear with the clutch out you have an axle not seated fully. If the speedo doesn't move you've got a blown diff or some other type of catastrophic transmission or clutch failure. 9 out of 10 times it's an axle not seated.
Old May 1, 2015 | 10:27 AM
driver side cv <br/>
passenger cv
yes they have oil on them, its from me spilling oil an not getting around to cleaning it off. these are pics from under the car.
Old May 1, 2015 | 10:29 AM
an i wouldn't be able to tell if my speedo is moving at all, my vss blew a while ago. iv been going off rpms.
the passenger side looks like its out but iv tried spinning it to see if it would go in any other way an thats as far as i can personally get it in.
Old May 1, 2015 | 02:08 PM
94EG8's Avatar
Seagull Management
Passenger's side axle is way out. Pull it back out and try again. You'll want to start it so the splines line up and then give it a sharp jab to seat it, you have to almost use it like a slide hammer.
Old May 1, 2015 | 03:41 PM
thanks a bunch, i thought it looked funny when i was under the car.
wonderingpanda
May 1, 2015 07:07 PM
1hgej1
Mar 30, 2009 09:55 AM
antivic
Jul 13, 2006 02:13 PM
bb4socal
Dec 20, 2005 12:13 PM
KekahaB18
May 15, 2005 09:17 PM
