Acura / Honda 4 Lug Conversion OEM BBK New Custom Rotors New Calipers
Contact: Joel 909 728 5033
Price: $950
Description: I will have better pics of the front & rear arms tomorrow. Selling to go 5 lug. No other reason.
Front: Ball Joints have not been replaced but removed was going to use extended BJ's
- GSR ABS Left front Knuckle/Spindle - Has new wheel bearing
- GSR ABS Right front Knuckle/Spindle
* abs is optional, and abs pick up works off the axle ring. If your car does not have abs it can still use this spindle/knuckle
- NEW Real ARP Extended studs ( spot welded for extra security )
- Fresh black paint job
- NEW Front 11" slotted rotors ( redrilled to 4x100 )
- NEW Front Rotor Hat Spacers ( used to center prelude caliper & rotors on gsr hub )
- NEW Nissin Legend Front dual piston calipers
- NEW Brake pads
- OE Lower ball joints included ( currently installed )
- NEW Truhart Extended Ball Joint / RCA
4x100 3mm Hubcentric Rotor Spacer 56.1mm
Rear:
GSR ABS Left Trailing Arm w/ ebrake cables
GSR ABS Right Trailing Arm w/ ebrake cables
- NEW Megan Racing 2000KGS Durometer T/A Busing
- NEW Rear 10.3" slotted rotors 4x100 - not pictured will snap some soon
- USED DC5 Rear calipers w/ brake lines
Optional:
4040 Prop Valve
1" BMC w/ 290v Booster
Price: $950
- NEW Brake pads
Rear:
Optional:
4040 Prop Valve
EJ6_PickUpStix
12
Jun 23, 2021 11:44 AM
busy work day.
