Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Coolant flush
Old Apr 27, 2015 | 10:48 AM
prodjay10's Avatar
Default Coolant flush
204k mi on my 2004 civic which means its time for a timing belt and water pump.
I bought a gates timing belt component kit which includes a warning that says premature water pump failure can be prevented by having a coolant flush done before.
Just wondering if anyone recommends a chemical flush or just a drain and fill.
Old Apr 27, 2015 | 05:53 PM
toyomatt84's Avatar
Sanji
Default Re: Coolant flush
Drain and fill.
Old Apr 28, 2015 | 01:29 AM
prodjay10's Avatar
Thanks.
Old Apr 28, 2015 | 12:43 PM
prodjay10's Avatar
Otta curiosity, when filling radiator with coolant is it necessary that the fans turn on twice? It takes an hour or more for them to turn on.
Also, assuming the car is at operating temperature, is it necessary to hold the accelerator at 2000 rpm to fill burp the system? I didn't and the heater was;t working. I then held the rpm at 2000 and the heater started working. Topped it off again and after that it worked fine.
Old Apr 28, 2015 | 04:27 PM
sytntyt's Avatar
generally I raise the front end up a tad, install my spill free funnel. add coolant, turn heat to full hot without the blower on and use a pedal depressor set at ~1500 rpms. works every time and usually takes 15min or so to cycle fans twice.
klion22
May 27, 2008 12:28 PM
rca33
17
Apr 22, 2008 01:03 PM
Utilitarian
Sep 14, 2007 11:20 AM
tianporn
15
May 21, 2005 09:16 AM
96_GSR
Jun 27, 2002 08:19 AM
