ef sometimes doesnt want to start- shortage problem?
Old Apr 25, 2015 | 02:12 PM
Ef4doorwagon's Avatar
Default ef sometimes doesnt want to start- shortage problem?
Sometimes my ef won't crank, dash lights turn on fuel pump and all that, then when I try n crank it, it just shorts out, all lights turn off. Then what I do to turn it on is I disconnect the neg battery, then reconnect it, and I press the gas pedal and crank it and it turns on. What's my issue?
Old Apr 26, 2015 | 07:58 PM
Default Re: ef sometimes doesnt want to start- shortage problem?
Edit* I cleaned the main ground wire that goes to tranny and neg terminal, had a little bit of green dust. Car started up fine, still don't know if it fully fixed it. I suspect either ignition wiring trouble or bad grounds. I did replace the ignition cylinder but not the wire part. I'd like to know if any one else had this issue and fixed it 100%
Old Apr 26, 2015 | 11:45 PM
B_CRUZ!'s Avatar
You should probably re solder your main relay. There are several threads here on how to do it.
Garry_90Civic
Jul 30, 2014 07:00 AM
Nerdskateful
Jan 22, 2014 03:32 PM
crookson speed
Jan 10, 2014 12:00 PM
ThaEfSwap
Oct 19, 2011 02:16 PM
bbrian
Jan 23, 2005 09:36 AM
