VTEC problems after timing belt replacement
Old Apr 24, 2015 | 03:03 PM
ugen's Avatar
Default VTEC problems after timing belt replacement
VTEC is not engaging after timing belt has been replaced. Is this likely due to improper alignment of camgears etc during installation? I fear that I will have to redo the install/check the work but I am looking for other things I should consider before I dot this. There are no CEL and I have checked the oil level. Oil is old though so I may do a oil change and make sure the coolant system is burped.
Any suggestions?
Old Apr 24, 2015 | 07:42 PM
holmesnmanny's Avatar
Default Re: VTEC problems after timing belt replacement
You can check the mechanical timing without removing the belts altogether so check first.
Old Apr 24, 2015 | 09:01 PM
backinblue92's Avatar
What holmes is referring to is checking your tdc against the flywheel marks that are under the block stamp in case u were wondering.
There's nothing associated with timing that would prevent vtec engagement that I can think of unless u disconnected something. The vtec solenoid, etc is on the other side of the engine. I mean, unless your timing was so off vtec won't engage but in that case I'd imagine the car wouldn't start either
Epperson
Jan 6, 2018 06:01 AM
SPEED FoRCE
Jan 14, 2010 05:06 AM
erok515
Jul 29, 2008 04:22 AM
simpsond
Nov 30, 2003 04:41 PM
Zulu888
Sep 30, 2003 05:57 PM
