95 honda accord automatic shuts of after 15 minutes
Old Apr 23, 2015 | 07:43 PM
jreyes16vmz's Avatar
Icon3 95 honda accord automatic shuts of after 15 minutes
Working on my other car and its a 95 the car will start then ill leave it running for like 15 minutes and its shuts off then I have to wait an hour or more tell it turns on I unplug the bolt on fule rail and gas was coming out so don't thank its a fuel problem fuse are good main relay is good what can I look at next thanks
Old Apr 24, 2015 | 11:58 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 95 honda accord automatic shuts of after 15 minutes
Check for any stored codes. If it happens after the engine has been heat soaked it could be an ignition pickup issue. Check for spark with a spare plug. Once the engine cuts out, pull a plug wire, install the spare plug and crank the engine while checking for spark. No blue/white spark then you know it is ignition. If strong spark, reinstall spark plug wire and remove the gas cap. Reinstall and see if the car starts. If it does then you know it is probably a EVAP issue causing a pressure issue in the tank.
fahim
Oct 24, 2010 12:57 AM
97accord_R
Aug 30, 2009 06:51 PM
94_civicEx
Jan 23, 2006 07:44 AM
accordlx87
Apr 4, 2005 07:20 AM
TriciaHoward
Jul 14, 2004 03:24 PM
