Technique for forming collector to fit a T3 flange
Old Apr 23, 2015 | 06:05 PM
LKSi's Avatar
Default Technique for forming collector to fit a T3 flange
I'm having a bit of a dilemma. I have figured out how to produce collectors, now I just need to figure out how to form them to fit a T3 flange. My collectors are 5-1 so I'm not even sure how to make them more rectangular with the angles. Please share any techniques that work without marring up the collector.
Old Apr 23, 2015 | 07:20 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Technique for forming collector to fit a T3 flange
Insert collector into appropriate pipe (2.5" for T3 usually), draw line around collector, cut around line, and radius flange.
You can also make a paper template and let the long sides hang down further, form in a vice, and then cut and radius. Probably plenty more ways than that as well...
Old Apr 23, 2015 | 07:47 PM
LKSi's Avatar
I understand how to cut it and what size the opening should be. I'm just seeking tips on going from circular to T3 without destroying the collector.
Old Apr 24, 2015 | 05:11 AM
98vtec's Avatar
moderator emeritus
http://spdexhaust.com/pdfs/Temp_Pages/Turbo_CT.pdf
Old Apr 24, 2015 | 05:41 AM
LKSi's Avatar
I don't want that 16ga transition piece to be a weak point in the collector
Old Apr 24, 2015 | 06:05 AM
weiRtech's Avatar
OG Fabricator
it is easier to form if it is slightly undersize. fully weld the collector off the flange. line up the flange over the bottom of the collector so that it is as centered as possible. weld the areas where the collector outlet and the flange are very close to the correct size. then use a couple ball peen hammers to shape/stretch the areas that are undersize.
boostedb20z
Welding / Fabrication
16
Jan 25, 2013 04:16 PM
Burntrubber87
Nov 3, 2006 05:42 AM
TurboSI56
Sep 14, 2006 09:29 PM
ExploitedRacing-HR
22
Dec 6, 2004 04:21 PM
