15x8 +36 or 15x7 +35?
Will be getting wheels soon and I'm curious how the 15x8 +36s will fit. I plan to run a close to stock offset and I don't plan to slam the car down, in fact I run ITR suspension so it looks stock. Will these fit with no problem or should I stick to 15x7 +35? I'd like to have the option to run wider tires later when I add power.
I ran 949 racing 6ul which are 15x8 +36 with 205/50r15 dunlops without a problem, all that was needed was to grind some(very little nothing crazy) on the rear upper control arms to keep them from rubbing the inside of the rim. in the time i ran them, i had the car low to the point where they tucked and also ran them with an inch of wheel gap. on ground control/koni yellows never had any issues.
Back in Black
Apr 22, 2002 12:24 PM
