12.8@107 All Motor 2000 Si
Old Nov 4, 2002 | 08:20 AM
J&D Motorsports's Avatar
Default 12.8@107 All Motor 2000 Si
We got a chance this weekend to run the Si on slicks and I am happy to say that the stock clutch held up enough to get a 12.8 out of the car. Somehow the stock GSR pressure plate with a Clutchnet disc held up enough to get a 1.73 60 ft. Hopefully we will get a full clutch setup by this weekend for MIR.
[Modified by SIKCX, 12:21 PM 11/4/2002]
Old Nov 4, 2002 | 08:33 AM
skunked's Avatar
Default Re: 12.8@107 All Motor 2000 Si (SIKCX)
Nice..
Old Nov 4, 2002 | 08:58 AM
Boostfed's Avatar
New User
I'm not gonna ask your set up I'm sure you've posted before, is it in one of these forums already posted? Congrats!
Old Nov 4, 2002 | 09:07 AM
CHEETAH's Avatar
very impressive for such a heavy car !!!
Greg
Old Nov 4, 2002 | 11:59 AM
Default Re: 12.8@107 All Motor 2000 Si (CHEETAH)
Thanks guys. It is a GSR motor with JDM ITR pistons and CTR intake cam,that's basically the meat and potatoes of it. Of course it has a Skunk intake manifold,ITR t.b.,cam gears, Iceman ram air,JDmITR header, blah blah blah.
Old Nov 4, 2002 | 12:17 PM
CTR94Joes's Avatar
What spark plugs do you run on this all motor setup. and ECU program do you use?
Old Nov 4, 2002 | 12:57 PM
hybridreams's Avatar
Default Re: 12.8@107 All Motor 2000 Si (CTR94Joes)
DAmn!! You have no idea how hard I've been trying to get my hands on an Iceman ram air inake kit for my 92 civic. grrr
the headlight thing
[Modified by hybridreams, 4:57 PM 11/4/2002]
Old Nov 4, 2002 | 02:20 PM
4piston's Avatar
Do you ahve any dyno numbers for the car?
Old Nov 4, 2002 | 02:31 PM
SergEK's Avatar
Good job man
Nice 60' too
What size slicks?
Serg
Old Nov 4, 2002 | 03:03 PM
NICHRIS143's Avatar
so you have the itr exhaust cam and a ctr intake cam? what kind of suspension set up do you have? i'd like to know the other blah, blah, blah's too... thanks
Old Nov 4, 2002 | 05:37 PM
redcxhatch's Avatar
Default Re: 12.8@107 All Motor 2000 Si (NICHRIS143)
Nice! Ya, fill in some of the blah blahs for us.
Old Nov 4, 2002 | 06:27 PM
Turbo R's Avatar
Default Re: 12.8@107 All Motor 2000 Si (redcxhatch)
very impressive!
Old Nov 5, 2002 | 04:55 AM
HRILSVTEC's Avatar
Good run fellas.
Old Nov 5, 2002 | 07:13 AM
JDMb18civic's Avatar
wut kind of slicks??
Old Nov 5, 2002 | 08:35 AM
Default Re: 12.8@107 All Motor 2000 Si (JDMb18civic)
The car has Ground Control coilovers and Tokico blue shocks in the front and white in the rear. I have no idea what kind of power the car is making, but I would have to guess it has to be in the 190 whp range. The slicks are 22x9-13" M&H on Volk Te37 drag wheels.We are using BCPR6E-11 NGK plugs from 90-91 1.6 SOHC and a stock GSR ecu with 9k rev limit, no fuel or timing mods.The intake cam is CTR and the exh. cam is stock GSR. As for the ram air,that thing was damn near impossible to find. You can get them from Erick's Racing (310)320-5788.
Old Nov 5, 2002 | 08:38 AM
Does anyone have any ideas on what I can take out of the car to lighten it up? I have removed the seats and the front bumper support and I don't want to make the car to unbearable since my wife drives it everyday. Any idea you have would be appreciated. Thanks, David
Old Nov 5, 2002 | 11:28 AM
THANKS!! I'll give them a call
Old Nov 5, 2002 | 01:27 PM
NICHRIS143's Avatar
stock gsr for the exhaust cam??? is there any reason why you kept it instead of upgrading to the itr or ctr? I'm trying to build my gsr and am stuck on what cams to get and headers... any help would be great...
Old Nov 5, 2002 | 01:45 PM
We decided not to waste the money on the exhaust cam due to the fact that we plan on putting Crower 402 cams in the car. The JDM ITR header is a great buy and makes good all around power.
Old Nov 5, 2002 | 01:54 PM
NICHRIS143's Avatar
any port and polishing, replacement of stiffer valve springs or retainers?
Old Nov 5, 2002 | 06:30 PM
HXMan's Avatar
The center support below the rear seats. Weighs about 40lbs.
Old Nov 5, 2002 | 09:05 PM
CTR94Joes's Avatar
Default Re: 12.8@107 All Motor 2000 Si (HXMan)
Hey do you have adj cam gears if so what did you set the intake came to. I have the same set up but I opt for the CM st2 and ITR FW and ex cam. with SK2 CG, P28 Mugen,VAFC etc. Never got it tuned to it's fullest.
Old Nov 6, 2002 | 02:50 AM
vntperformance's Avatar
bump for dave...nice run against me!
vnt
Old Nov 6, 2002 | 05:27 AM
(teh)H2OUUP2's Avatar
Default Re: 12.8@107 All Motor 2000 Si (vntperformance)
ALL Moto, No Moto, Turbo Moto, Hybrid Moto.
Here is the culprit, 12.8 @ 107, info and pictures of the set-up @ http://www.heavya55Si.com
Old Nov 6, 2002 | 05:32 AM
One idea, try to get rid of all those ideas and formula and whatever out of you head, should take some brain mass away and save you some weight, or get a smaller hard drive with less weight and more compacity.
