FS: Civic Integra Turbo Parts
I need money to fund my build so all prices are negotiable. Most prices include shipping within the US unless otherwise stated. Located in Palmdale, CA for larger items. You can text me @ 661-433-8135
D-series lightweight 8.5lbs flywheel needs resurface - $40
Parting out D16Z6 block. Missing rods, oil pump, oil pan.
Crank is good and was balanced - $30 +shipping
rear main seal plate - $10
water pump less than 10k miles - $15
alt bracket - $10
crank girdle - $25 +shipping
oil pickup $20
trans brackets - $10 each
D15b7 2-bolt engine post mount with brace - $30
engine lower torque mount/ac bracket - $30
complete D15B head, no valve cover - $50 +shipping
D-series manual starter - $35
d-series trans torque mount/bracket - $30
turbo intake s-pipe 2.5" with filter and 2" reducer coupler - $40
motorola 2.5bap map sensor with homemade plug and play harness - $25
mac electronic boost control solenoid with L-bracket - $25
alt bracket - $10
oil pickup $20
Prosport 52mm Performance blue/white mechanical vac/boost gauge, comes with original packaging/documentation - $25
GSR gauge cluster - $75
civic OEM battery cables - $15
red aluminum short shifter - $15
92-95 civic cruise/dimmer/blank switches - $10
92-95 civic defroster/aftermarket fog light switch - $10
d-series alternator - $25
d15b7 upper timing cover - $15
d16z6 upper timing cover - $15
a/c pulleys - $10 each
d16a6? 2-bolt engine post mount - $15
d-series a/c bracket - $15
d-series oil pump timing gears - $10 each
d-series a/c condenser brackets - $8
d-series upper radiator hose spout - $10
d-series rear motor mount - $15
d-series upper alternator bracket - $10
d-series throttle cable bracket - $8
d-series v-tec solenoids - $10 each
92-95 civic coolant reservoir bracket - $10
d16z6 crank pulley - $15
d15b7 crank pulley - $15
92-95 civic oem tow hooks - $10
d-series oil breather black box - $10
d-series P/S bracket - $15
92-95 civic radiator stay - $5
92-95 civic coolant reservoir cap - $5
92-95 civic drivers side engine harness plug bracket - $8
d16z6 cracked but functional IACV - $15
d-series oil breather black boxes - $10 each
92-95 civic front door handles bayside blue - $25
d-series ignition coils $15 each
map sensors $10 each
d-series rear coolant pipe - $15
d-series 3-bolt post mount $15
d16a6? IACV $15
oil pressure sensors - $10 each
ecu cover - $15
coolant temp sensor - $8
obd1 injectors $5 each
speed sensor d16y8? - $10
16 oem lug nuts - $10
d-series lower alt bracket - $10
d-series 2-bolt post mount? - $15
d15z1 EGR valve - $15
d15z1 firewall mounted vac. box - $15
d16z6 TB gasket in package - $8
d-series thermostat housings - $15 each
d-series intake manifold braces - $15 each
d-series rear mount t-bracket - $25
speed sensor - $10
92-95 civic moon roof switch $8
92-95 civic block off switch cover - $8
92-95 civic oem fuel pumps - $10 each
d-series black thermostat housing - $15
d-series PCV valves - $8 each
d-series upper radiator spout - $10
d-series intake manifold brace - $15
d15b7 upper/inner timing cover - $15
d-series oil dipsticks - $15 each
b18b1 valve cover - $40
parting out b18b1 valve train previous owner destroyed hardware and head in process. I have rockers, springs, retainers, caps, cams, temp sensor, coolant spout, valves, etc...
parting out d16z6 valve train its all there minus cam. just exhaust manifold stud broken not fixable - $30 for everything except head itself
d16z6 valve cover blue - $40
92-95 civic yellow fog lights no covers - $15
literally a giant box full of obd1 plug pigtails - $8 per plug with pins and wire leads, buy more than one for combines shipping.
d16a6? IACV $15
ecu cover - $15
speed sensor - $10
d16z6 resurfaced and balanced flywheel - $40
integra front seats with rails. no rips or stains that some cleaning wont mend - $100 picked up
integra black dash - $50 picked up
integtra climate control - $30
integra air bag covers, no airbags - $20
d-series shift linkage - $40
integra rear seats - $50 picked up
D-series heater core hoses with valve - $20
D15b bare intake manifold -$25
D16z6 powdercoated blue fuel rail - $20
D16y8 cam gear - $12
JUST be this guy:
JUST be this guy:
fltblkEFhatch
Jan 31, 2010 10:15 PM
Danronian
Mid-Atlantic (Sales)
78
Nov 23, 2007 07:32 PM
