Distributor integra type r
Old Apr 17, 2015 | 04:14 AM
Shayne Jonez R's Avatar
Default Distributor integra type r
between integra gen 3 are distributor bearing, shaft and gears the same could i swap one from an ls into a type r housing dizzy my bearing is gone need it replaced,
Ive got a Pr4-d02754 housing distributor here not sure if its a ls or gsr etc any identification from someone would be great so far ive replaced the bearing shaft ill post picture before and after stay tuned.
thanks guys any help/advice is appreciated
Old Apr 17, 2015 | 06:14 AM
B16EJ's Avatar
Default Re: Distributor integra type r
If you have an unknown distributor shaft it's very easy to tell If it will work with your distributor housing just physically try and see if it fits, and that the rotating parts are the right clearances, just turn the shaft and watch to see what is happening it's very easy to tell If the shaft will fit and work.
I've built my own distributors from spare parts you can mix and match I used a gsr housing and shaft, 98 civic si distributor sensors, gsr ignition coil, and type r ignition control module, and the distributor works awesome. If you need more info I suggest being clearer with your questions.
Good luck!
Old Apr 19, 2015 | 08:34 AM
B16EJ's Avatar
Originally Posted by Shayne Jonez R
Hey i put back everything together pretty accurate and i went to put it on the head and when i started the car it quickly turned off after it started, Ive heard you could possible install it 180 degrees whack, how would i go about to fix this situation do i take off the end part of the dizzy that goes into the cam and flip it?
Yes just take the distributor off and turn the "key" 180° and put it back on. When you put a distributor on it should slip on with very little resistance, if you have to force it on that's a good sign that it's on backwards.
I've done this myself, i even ended up breaking both teeth on the key completely off, and had to fish them out with a magnet, there's a small Lil bowl that the teeth fall into if this ever occurs. Good luck
Old Apr 19, 2015 | 11:22 AM
ive started the car and got a check engine light not sure what the code is
Old Apr 19, 2015 | 05:26 PM
FlewByU352's Avatar
I've rebuilt several distributors for myself along with others. Even D series internal parts swap over. You just have to match the housing to the motor as in B series/D series and then VTEC/Non VTEC. I haven't been able to figure out which part exactly makes the ITR distributor allow less ignition change.
Any other distributor can from one extreme to the other on the slotted ears change timing maybe 50 degrees. The ITR ones only allow maybe 35 degrees. I figured Honda did this to prevent accidental detonation being that it is already a higher compression motor. 18 degree advance is almost maxed out on the ITR distributors labeled TDU86U or TDU87U IIRC.
Also, if anyone has information as to where I can buy OEM bearings and seals for distributors that would be awesome! I've had a few come through with bad internal seals and I can't find a part number for solely that.
Old Apr 19, 2015 | 06:57 PM
B16EJ's Avatar
If the car is running I guess thats a good sign, but first you should figure out what your code is, at least you will know where to look next.
Scanners are pretty cheap nowadays or you could always check by counting the check engine light flashes by shorting the blue plug behind your glove box.
Is the car revving over 3500 rpms? My car was throwing the code for the crank position sensor which is one of the sensors in the distributor, but still ran fine with the code.
Old Apr 20, 2015 | 07:09 AM
I've got the codes they are,
9 - CYP (No. 1 Cylinder Position)
and
11 but the code list has nothing for 11
its one long blink followed by 1 quick blink and then 9 constant quick blinks
Old Apr 23, 2015 | 06:20 AM
B16EJ's Avatar
How did u manage to solve the issue? Sometimes it's best to end a thread with posting up your solution, that way in the future if someone has the same issue and are searching they might stumble across this thread with your solution.
It's one way to make a positive contribution to the forum. Thanks
Old Apr 23, 2015 | 01:30 PM
I didnt resolve it B16EJ, Im so frustrated with problems with this car theres just too many i dont know where to start. I just found out that my ecu on this car is a P30 ECU not the original p73 for the type r and when i move my ecu while its connected to the car when its on it makes the rpm jump like no tommorow and if it stays in one position its normal there is also a obd2 to obd1 harness connected to this ****.
So i thought it was just my distributor making my rpm do this turns out i was wrong, im still stuck on a cel 9 code ive taken it off multiple times to adjust the positioning of the sensor and still nothing, ive also checked the resistance on all sensors and they seem to be good at 390ohms the part im going to have to try next is exchanging from my old shaft distributor the cylinder position snail looking part the holes in this part are way different from the new dizzy shaft im thinking the sensor only works with that.
Old Apr 23, 2015 | 03:14 PM
FlewByU352's Avatar
I do have a P73 ECU on a shelf if you think that's the problem.
Old Apr 23, 2015 | 05:34 PM
B16EJ's Avatar
That sucks I'm sorry to hear that...
Do u know anyone with a known good distributor and/or p73 ecu? If you were local I'd let u try mine out to see if it wild fix your problems.
Is the obd2 to obd1 harness good quality? I would try looking at your wires because If moving the ecu around makes the rpms jump I would have to think there is an exposed wire somewhere or a loose connection possibly?
Those are most likely the things I would do next. I hope u figure out I know how frustrating it is, hang in there.
Old Apr 25, 2015 | 08:18 AM
why is my ecu like this inside the connectors?
Old Apr 25, 2015 | 08:26 AM
slooogsr's Avatar
Looks like water damage to me... Corrosion? How does the ecu look inside?
Old Apr 25, 2015 | 06:34 PM
B16EJ's Avatar
Well it looks like you found your problem. Clean everything up and open the ecu and see if there is corrosion inside the ecu also.
And clean the wire harness while you are at it. That's actually not so bad as long as nothing is damaged I think if you clean everything you should be OK. That kind of corrosion would definitely start interfering with the signals.
Old Apr 26, 2015 | 01:59 PM
Bently_Coop's Avatar
Steve at Heart
Both of these images show electrolysis/corrosion inside the ECU connections. Also appears your ECU has a chip in it which is what the top image shows on bottom right. Replacing the ECU and verifying the harness is not the same should be the priority in this situation. If you can't locate a stock ECU try a chipped P28 with the same base map.
jdmdelsol51
Sep 17, 2014 05:11 PM
Dohcvtec59
Jan 6, 2005 08:00 PM
theslugbug
Dec 12, 2003 10:03 AM
Quade
Jun 13, 2003 07:16 AM
Soled Out
Jan 20, 2003 10:24 AM
