garage sale all offers considered
Old Nov 4, 2002 | 07:14 AM
W0oT's Avatar
Banned
Default Garage sale all offers considered UPDATED!
Any offer is considered/trades are considered (see WTB on sig). can take pics of everything. Items can also be picked up or I will travel and meet up w/ u if your no more than a hour drive for some parts... Check out my website for some pics.
Btw I accept Paypal and money orders. also AIM is the easiest way to contact me i'm allways on... just IM me at Simon IBP
http://cluboms.homestead.com/Forsale.html
<U>Honda OEM Parts</U>!!! : All items still in original honda package and un opened.
part number description
90213-PH3-000 - Valve Cover nut
81515-SH0-A312B - Cover left seat
95701-0802008 - 1" 12mm head bolt
90371-SR3-000 - nut,flange,12mm
90363-SF1-000 - castle nut
95701-0601008 - 10mm/10mm bolt
90681-693-000 - clip white body interior
19511-PA6-003 - hose clamp
90428-PD6-003 - crush ring
90364-SG0-004 - nut 10mm (2)
94303-05080 - dowel pin
19305-PT0-000 - thermostat gasket
44347-SB2-003 - cv shaft ring seal
33120-SH3-A01 - turn signal bracket (88-91 civic)
32777-PR3-010 - plug wire holder (B series)
19506-P75-000 - eacv inlet hose (B series)
12513-P30-000 - cam seal (B series)
62521-SB2-000 - license plate nuts 88-91 civic front bumper
71591-SH3-010 - bumper brackets rear side (88-91 civic)
75523-SD4-003 - seal packing (88-91 civic rear center garnish)
92201-080500H - 2" 10mm bolt
90130-693-000 - 10mm screw (supposidly mudflaps for 88-91 civic but too small)
B16a:
-88-91 Civic SIR Intermediate shaft - 50$ + Shipping.
-B16a Sir1 misc parts- All used. (2 of everything)Clutch, oil pump, water pump, Timing belt side mount, transmission arm,Intake manifold bracket, front and top pass side tranny mounts.
-B16a Sir1 Intake Manifold- Great condition, from obd0 PR3 40$ + shipping.
-B16a Sir1 Fuel rail- Great condition, from obd0 PR3 20$ + shipping.
-B16a Sir1 Stock Camgears- Great condition, from obd0 PR3 20$ + shipping.
-B16a Sir1 Stock Cams- Great condition, from obd0 PR3 50$ + shipping.
-B16a EF9 SiR engine harness- CUT!!! missing 1 injector plug and section that plugs into ecu harnes, along with another section, pics comming soon, good vtec and dizzy plugs. good for wiring w/ OEM PINS.... 40$ + Shipping then to ebay.
-B Series AC Compressor- 50 + shipping
D16 + 4gen civic:
-JDM ZC DOHC Cams- Great for regrind. 50 + Shipping.
-90-93 teg Rear trailing arms- With upper control arms, ef rear disk swap. 150 + Shipping.
-JDM EF Coin box- Blue 20 + shipping. see pic in post
-88-91 Civic Skunk2 Drag Launch Springs- 50$ + Shipping.
-88-91 Civic Si Shiftlinkage- Both pieces make offer.
-88-91 Civic Si Shifter- see pic in post
-90-91 civic si cluster plugs- $15 Shipped.
-D16 injectors non obd- $20 + Shipping.
-1990 honda OEM radio- AM/FM quartz $15 + Shipping.
-91 civic si swaybars- front and rear. 75$+ Shipping obo.
-94 LX Fuel Pressure Regulator- Used, Good condition. 10$ + Shipping.
-d16z6 Sohc vtec oil squirter assembly- no sensor 10$ + Shipping.
-Civic map sensor- (2) From 91 Si 1.6ltr. 12.50$ea. + Shipping.
-OEM springs- (2sets)1988/89 dx hatch,(1set) 91 si. . 20$set + Shipping.
-1991 Civic Si Fuel Pressure Regulator- Used, Good condition. 10$ + Shipping.
-1991 Civic Si hatch rear upper wing- (2) Black, great condition. Not jdm. 20$ + Shipping each.
- 1991 Si 3dr rear bumper- (2) black, needs refinishing 35$ + Shipping each.
-88/89+1991 civic Si A/C fan- (3) @ 15$ea + Shipping.
-1988 Civic complete motor- D15 w/ auto tranny and ecu. 75$ + Shipping obo.
-1989 Civic D15 complete motor- no tranny (t-belt snapped (valves should still be good) crank pully cannot be removed chip in block behind pulley from attempt at removal). 50$ + Shipping.
-1991 Civic Si Rear Hatch- Black w/ glass little rust (black inner plastic panel). 25$ + Shipping. (wing optional)
-1991 Civic Si Hood- Make offer, good condition, black.
-D16 block- 91 si complete unknown milage. Make offer.
-D16 head- 91 si unknown milage, no dizzy or manifolds. Make offer.
-91 l3 tranny- 5 speed 91 Si. Make offer.
-1991 Civic Radiator support- (2)black usdm, 20$ + Shipping.
-1988 Civic Radiator support- Red usdm, 20$ + Shipping.
-1989 Civic DX intake box- OEM 10$ + Shipping.
-1988 Civic DX Gauge Cluster- Un-molested. make offer
-1988 Civic DX Dash- Complete pickup only. 100$
-88-91 civic crx feels rear fender flairs- 125 + shipping
-1988 Civic DX Tail lights- 20$ pair + shipping. no center garnish
-1990 Civic Si Tail lights- 50$ pair + shipping. no center garnish
-1990 Civic Drivers side headlight- 30$ + shipping.
-PM6- from 5 speed crx si. 45$ + shipping.
-88-91 civic crx front/rear upper/rear lower strut tower bars- make offer + Shipping. all 3
ZC tranny- needs rebuild or canibalize for hybrid tranny. make offer
ZC ACT Clutch- used make offer.
Misc. parts-brake booster, Rear wiper motor, Tail light harness, aftermarket OEM drivers side mirror. Just ask we prolly have it if it has to do w/ a 88-91 civic.
-H23 Block- taking offers
-H23 cyl head- apart comming soon
Audio Stuff:
-Kicker competition- C-10 8ohm sub, old plain black sub says Kicker in white sounds great, no tears. ... + Shipping.
-2 Coustic 8" subs- 2 HT-608 component subs, 100watt rms reccomended. .... + Shipping.
-2 Radioshack DVC 8" subs- 40watt rms max. Make offer + shipping. free just pay shipping.
all offers are considered....
Modified by Majin Vegita at 6:45 PM 11/28/2004
Old Nov 13, 2002 | 08:53 AM
ITR981002's Avatar
Default Re: garage sale all offers considered (Nismo240sx1)
Can you send pics of the Saab FMIC? to jjenkins@harlemfurniture.com
Old Jan 10, 2003 | 06:19 PM
Mocky57's Avatar
do you still have the rear speaker pods from your hatchback? if so, how much do you want for them?
Old Mar 6, 2003 | 10:08 PM
J.P.'s Avatar
1988 Civic complete motor- D15 w/ auto tranny and ecu. 100$ + Shipping obo.
what will you take for that motor, not trans and ecu, shipped to 35603??
hows it run? and that will work with a 5spd trans right? thanks
jP
Old Jun 15, 2003 | 03:36 PM
xrtdac
Guest
Posts: n/a
Default Re: Garage sale all offers considered UPDATED! (Nismo240sx1)
What size 17' tires are on those rims. I may be interested in just the tires.
Old Jun 22, 2003 | 05:50 PM
smokey2.0's Avatar
Default Re: Garage sale all offers considered UPDATED! (xrtdac)
-D16z6 93 Del Sol Si sohc Vtec solenoid- W/ oil pressure squirter assembly. Good condition $30 + shipping will fit any 92-95 d series vtec.
i'll take this, let me know how much shipped to 33071!
Old Jun 22, 2003 | 07:48 PM
xrtdac
Guest
Posts: n/a
coo. I love the GT8s but I got inperios now from 5zigen and they look better on my car.
Old Jun 23, 2003 | 08:49 AM
xrtdac
Guest
Posts: n/a
205/40/17????? How much for the tires only.
Old Jun 23, 2003 | 08:52 AM
SprayinCX's Avatar
Default Re: (xrtdac)
you still got the h23 longblock. i need everything but the tranny
Old Jun 23, 2003 | 09:23 AM
spun Vtec's Avatar
Default Re: (SprayinCX)
ill trade you 90-91 integra back seats w/ headrest that i have in my hatch + $$$ for that sci pm me
im in pa also have other stuff: https://honda-tech.com/zerothread?id=516061
Old Jul 1, 2003 | 11:15 PM
xrtdac
Guest
Posts: n/a
im interested in those 450's
price??
Old Jul 28, 2003 | 07:26 PM
xrtdac
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrtdac &raquo;</TD></TR><TR><TD CLASS="quote">205/40/17????? How much for the tires only.</TD></TR></TABLE>
&gt;&gt;&gt;
Old Aug 11, 2003 | 11:53 PM
xrtdac
Guest
Posts: n/a
again. How much for the tires only maybe?
Old Aug 12, 2003 | 11:47 PM
xrtdac
Guest
Posts: n/a
word.. brand and tread left. I can always buy one more.
Old Feb 18, 2004 | 07:10 PM
W0oT's Avatar
Banned
need something you don't see ef related pm/e-mail/aim me!
Modified by Majin Vegita at 10:42 PM 3/29/2004
Old Mar 5, 2004 | 12:44 PM
W0oT's Avatar
Banned
Default Garage sale all offers considered UPDATED! 56k beware
mmmm pics
power'd by honda pads
OEM Shifter
90-91 sidemarkers think only 1 left not even a pair
NON OBD B16 camshafts PR3
Coustic 8's in crappy sealed box.
I believe this is a Civic console, was told it's a teg one but definately looks nothing like mine.
Pioneer universal XM radio
Skunk2 Rear Drag launch springs for EF
Modified by Majin Vegita at 3:06 PM 10/15/2004
Modified by Majin Vegita at 7:31 PM 10/30/2004
Modified by Majin Vegita at 12:02 AM 11/19/2004
Old Mar 8, 2004 | 10:45 PM
Kei-EF8's Avatar
Default Re: Garage sale all offers considered UPDATED! 56k beware (Nismo240sx1)
Interested in........
"1989 Civic Si Flywheel- Freshly resurfaced. 65$ Shipped"
pls check IM
Old Mar 12, 2004 | 08:48 PM
Smooth89Hatch's Avatar
Default Re: Garage sale all offers considered UPDATED! (Majin Vegita)
how much are you asking for the door panels, seats, and dash?
Old Mar 18, 2004 | 08:24 AM
bikerchris13's Avatar
I suck at making offers. Ignore me please.
Modified by bikerchris13 at 12:06 PM 4/2/2004
Old Apr 1, 2004 | 06:40 PM
Smokinsax's Avatar
The Boot
so where is that armrest?
Old Apr 7, 2004 | 06:03 AM
how much for the 2 that are grey w/tweets?
Old May 6, 2004 | 05:43 PM
91d15hatch's Avatar
drivers side mirror? if so how much?
Old May 24, 2004 | 01:00 PM
b16_madman's Avatar
Default Re: garage sale all offers considered (Mocky57)
pm sent
Old Aug 12, 2004 | 11:04 PM
HatchBox's Avatar
Skoobie no more...
Default Re: garage sale all offers considered (B16_madman)
bump for the hell of it
Old Sep 16, 2004 | 05:16 AM
type Gendy's Avatar
bump for an old forsale list
