just picked up a new ac condensor fan
Tested the new fan before i installed, worked. Long story short, my old fan took a dump on me, so i ordered new one. So i put it in and ran the ac, which if working correctly the fan should run right? No go. Need to know where to start as far as diagnosing the problem?
It should run when the ac is running. Youre sure the AC is indeed running? The compressor is running right? If it is low on refrigerant...neither will come on. Now let the engine run for a while until the engine gets warm enough to need the fan to run. Both fans should kick on. If it doesnt...then I would remove the wire...and turn the AC on again, check for 12V at the plug. If you have 12V then I would suspect the fan again. I would then run 12V directly to the fan...see if it works.
Key on, remove the connector from thermo a on the t-stat housing (where the lower hose connects) and use a piece of wire to jump the wire side of the connector. BOTH fans should run.
To "holmes" point - anytime the key is "on" and the conditions are right, BOTH fans run. The only time ONE fan would run (3rd thru early 6th gens) is when the key is off.
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
EK k kay
Oct 29, 2005 10:48 AM
FOrSfEd
Jul 14, 2004 05:08 PM
