shaving/cutting calipers to fit wheels
Old Apr 10, 2015 | 06:18 PM
nyckid's Avatar
Default shaving/cutting calipers to fit wheels
wanted to know what is the purpose of the caliper carrier bar? Ive notice many calipers don't even have this.
anyhow this is the part that is slightly hitting the back of my front wheel. cant use spacers do to the offset
http://www.sn95source.com/topic/4659...-thread/page-2
http://www.moddedmustangs.com/forums...e-caliper.html
Old Apr 11, 2015 | 09:23 PM
NWDyno's Avatar
Default Re: shaving/cutting calipers to fit wheels
I've shaved them without any issues stopping at a trap speed of 170mph. I had to shave the actual part that holds the pad as well.
Old Apr 12, 2015 | 05:17 AM
KevinEF7's Avatar
You can get away with SHAVING a few mm, not eliminating
Old Apr 12, 2015 | 11:09 AM
nyckid's Avatar
found the info. you can shave and you can also just cut off the carrier bar without any issues.
can provide links for anyone interested
Old Apr 12, 2015 | 12:31 PM
KevinEF7's Avatar
Please do post the link.
Old Apr 13, 2015 | 10:38 AM
nyckid's Avatar
VWVortex.com - Default shaving/cutting calipers to fit wheels
Old Apr 14, 2015 | 04:43 PM
KevinEF7's Avatar
"Go ahead and cut off the front bar. It's really just there for manufacturing. When the bracket is being machined, the two rails that the pads ride on are broached. The cross bar keeps the bracket from twisting into a pretzel while being broached.
The brackets without the front bar are machined differently, so they don't need the cross bar.
I used to engineer brakes, and we went through lots of projects and tons of effort to design brakes without the cross bar, and re-design the cross bar off of products that already had one. It would save a lot of weight, reduce material cost and also make the pattern layouts easier at the casting foundry."
riruiz_88
Suspension & Brakes
Feb 25, 2012 12:08 PM
solorex
Feb 27, 2010 10:00 AM
vangaurd
Suspension & Brakes
May 19, 2009 06:47 AM
highneo
Dec 9, 2008 01:49 PM
BB6-213
May 21, 2006 09:11 AM
