Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
crank no start
Old Apr 9, 2015 | 08:06 AM
str8kustomz's Avatar
Default crank no start
Hi my civic stopped running and won't run again I have tested all fuses and change the main relay and fuel pump cleaned up the ground points tested the ohms on the injectors there all reading 12.5 if I pour fuel into the throttle body and turn the key it runs until the fuel is all burned out I remove the line off of the fuel rail it was dry could some one please help
Old Apr 11, 2015 | 09:33 AM
tamboo's Avatar
10 Year Member
Default Re: crank no start
new fuel filter lately?
Old Apr 12, 2015 | 04:58 PM
Former User's Avatar
Does the fuel pump prime?
Old Apr 13, 2015 | 01:53 AM
Yes changed that also
Old Apr 13, 2015 | 01:55 AM
Yes after I tried to start it a couple times I removed the fuel line off of the pump and the pump itself start to push fuel out
jerryscherry
13
May 8, 2014 10:08 PM
4doorcivic9
Jun 11, 2008 06:31 AM
Cameron60
Jan 16, 2007 06:04 PM
diewX3
Jan 11, 2005 11:50 AM
shivern
Dec 17, 2004 08:35 AM
