93 civic turns on whenever it wants
Old Apr 6, 2015 | 05:08 AM
smok3sz's Avatar
Default 93 civic turns on whenever it wants
Hi my name is Axel and i have a 93 civic auto which was converted to manual i bought the car as a shell already converted and put an ls swap in it. Recently i been having an issue that the car turns on whenever it wants sometimes i get in and it starts on the first try other times i can be cranking it for 2-3 mins before it even starts. The starter is brand new, i have also swapped the main relay and ecu from a another working car. When i jump the starter with the key in the on position the car starts right up no problem. I have checked the voltage at the power wire to the starter it reads 12+ volts and the signal wire reads 12+ Volts as well when i try to start it. But the starter fuse #18 only reads 6-8 volts. I have changed the fuse and checked all other fuses and no luck. Anyone have any idea what is wrong?
Old Apr 6, 2015 | 08:04 PM
Former User's Avatar
Default Re: 93 civic turns on whenever it wants
This^ suggests a cranks but won't start problem, but later info seem to suggest a no crank problem. Which is it? Or both?
Old Apr 17, 2015 | 12:41 PM
smok3sz's Avatar
its pretty much both sometimes the car starts no problem then other times it doesnt crank i can hear the starter solenoid engage but not the starter motor the starter is brand new and has been tested.
Old Apr 17, 2015 | 03:53 PM
Solster's Avatar
try replacing the ignition switch.
If it starts every time you jump the starter then the ignition switch is bad
Schultzie
Jan 23, 2013 09:46 PM
Schultzie
Honda Civic (2001 - 2005)
Jan 23, 2013 11:09 AM
dyce_b17
Aug 24, 2012 09:00 PM
purple_civic94
13
Apr 26, 2012 09:39 AM
SIR_APPROVED
Jan 24, 2010 03:59 PM
