Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Electrical gremlin 06 civic ex
Old Apr 5, 2015 | 06:12 PM
Shaiddai's Avatar
Default Electrical gremlin 06 civic ex
Hi, I have an electrical issue that has been hard to pinpoint. I have replaced the battery, alternator, fuses, the windshield wiper drive motor, and most of the relays. The battery dies every night and I have to jump my car every day, and then it runs for about 45 min to an hour without the battery light and then it reappears. And my car dies again. Any suggestions as to what might be the cause?
-Shaiddai
Old Apr 6, 2015 | 08:01 AM
97emsedan's Avatar
Default Re: Electrical gremlin 06 civic ex
Check all of your wiring and connectors for cracks in the insulation which could expose the wires. If they are grounding, you will have a short that will drain the battery in short order, pardon the pun...
Old Apr 6, 2015 | 05:14 PM
Shaiddai's Avatar
Thank you, I've actually checked most of the wiring, but it is fully possible that I missed something. I'm thinking about doing a big 3 upgrade. Would that possibly solve my problem?
Old Apr 6, 2015 | 07:51 PM
lazlong's Avatar
I'd check for parasitic draw: With the car off, disconnect the negative battery cable and put a test light in-line between the cable and the battery terminal. If it lights up you have a parasitic draw. Pull fuses 1 by 1 until you find the circuit that makes the test light go out. It's then a matter of finding the short in that circuit. Start with any aftermarket wiring first.
***DO NOT PULL ANY AIRBAG FUSES***
willnfrank
Jun 26, 2013 11:30 AM
gsrpedro
14
Feb 5, 2008 01:14 PM
fumpster
Dec 5, 2007 11:24 AM
Deano_D aka "Brick Top"
Feb 25, 2006 08:15 PM
lemongreenhatch
Sep 5, 2005 06:33 AM
