98 cr80 plug fouling out
Old Apr 5, 2015 | 06:37 AM
95eggsr66's Avatar
Default 98 cr80 plug fouling out
Top end was just rebuilt along with pro circuit exhaust and reeds. Was jetted correctly (i think) ran great for the first hour or two. barely any smoke and ran top. towards end of day plug was getting wet. blowing a little more smoke than usual at wot. fouls plug, wait a half hour or so bike starts back up and runs perfectly.
Do i need to rejet after top end is broken in? run hotter plug? any suggestions
Old Apr 5, 2015 | 04:46 PM
MSchu's Avatar
My Name is Nobody
Default Re: 98 cr80 plug fouling out
are you using pre mix or oiler? (I suspect oiler)
have you done an appropriate plug check?
Old Apr 6, 2015 | 06:42 PM
ej1995's Avatar
Verify that you have the proper plug was also the first thought that came to my mind. Heat range plays a major factor in an application like that.
You said more smoke, was it a heavy oil smoke(blue) or a heavy fuel smoke?
Old Apr 8, 2015 | 06:32 AM
95eggsr66's Avatar
it was more of a blue smoke. i mix only honda 2r oil and 93 octane 32:1
i will try a hotter plug and if not I assume it will just have to be re jetted.
gas was getting to bottom of tank possibly settled oil playing a factor
Old Sep 29, 2015 | 02:22 PM
Josh377's Avatar
Cr dirtbikes are always fouling, when you kick dont give as much gas and it will stop. Also how much did you pay for your spark
Plug?
takiwa
Apr 3, 2015 05:01 PM
Powelly
Apr 19, 2009 05:18 AM
hondapwr
Jan 26, 2008 07:44 PM
mugenspoongsr
Honda Motorcycles
Jan 2, 2007 01:21 PM
janz3n
18
Apr 20, 2006 06:34 AM
