rsx/ep3 calipers on my usdm itr 5 lug conversion
Old Apr 4, 2015 | 06:47 AM
guru350's Avatar
Default rsx/ep3 calipers on my usdm itr 5 lug conversion
What up HT I have a daily driven eg6 with a 5 lug conversion and both my rear calibers need changing.I searched high and low no store carries them or can order them for me .So i searched the forum and found that rsx/ep3 calipers may fit can anyone verify or point me in the right direction with a d.i.y and a parts list
thanks in advance
Old Apr 4, 2015 | 07:01 AM
Built2grind's Avatar
Default Re: rsx/ep3 calipers on my usdm itr 5 lug conversion
I'm pretty sure that they will bolt up, but you will have to remove the calipers to bleed them because the bleeder will be upside down. Pain in the @$$. Unfortunately there are no direct replacements for the rear calipers from any other models. The exact caliper is unique to the ITR and CTR. I would personally buy brand new calipers from the dealership. They run about $200 each from Del Ray Acura online. You can find remanufactured versions for about $50 less each from Cardone or other similar companies. I've been searching high and low for a set as well and I finally decided to bite the bullet and purchase new. Good luck.
Old Apr 4, 2015 | 07:16 AM
Eight09's Avatar
You will have to swap the left and right side calipers and bleed them with the caliper pointed up with something wedged in the caliper. Its definitely a pain and not worth the trouble on a street car.
Old Apr 4, 2015 | 04:48 PM
dc4teg95's Avatar
Thought 97+ prelude used the same brake calipers front and rear as the itr?
Edit* just checked part numbers and they are different.
Old Apr 5, 2015 | 01:03 AM
guru350's Avatar
ok thanks what about the ebrake cable will i lose it
Old Apr 5, 2015 | 07:52 AM
OmarR's Avatar
ITR rear calipers are $60 a piece on Rockauto along with a $65 core. Core cost is refunded when you send back your old calipers.
Old Apr 5, 2015 | 10:08 AM
guru350's Avatar
add it to your cart and try to checkout
Old Apr 5, 2015 | 08:29 PM
OmarR's Avatar
It's going be on the high end price wise because the core cost is included. Once you receive the new parts and install them, ship back the old ones and you'll be refunded the core cost.
There's 5% discount codes posted on various online coupon sites you can use too.
Old Apr 13, 2015 | 11:26 AM
Honda R's Avatar
couldnt you just flip flop the calipers so you dont have to bleed them upside down?
guru350
Apr 6, 2015 09:45 AM
ej1bmx
Suspension & Brakes
Feb 13, 2012 12:00 PM
spaceman00
14
Apr 30, 2007 11:57 PM
