ABS light...
Old Apr 3, 2015 | 08:59 AM
Z99doc's Avatar
Default ABS light...
I went to pick my car up from inspection, and after I started driving it I noticed a little clicking sound. It happened for a min or so then my abs light poped on. i did look around the abs unit and did notice some fluid leaking out of a tube which is now discontinued through Honda... so first question is could this leak be my problem? second question why is this clicking going on and then all of a sudden my abs light comes on? third and final question where can i find tubing to replace this tube?
Part number for the tube is 57370-SS0-A50 if you use hondapartsnow.com it is a 92 honda prelude 2.3 ka5mt and this part number will be listed under ABS Accumulator and will be #8 in the diagram.
Old Apr 9, 2015 | 10:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: ABS light...
Did you even check what the ABS code was set?
jrmullins85
Sep 24, 2015 05:40 AM
DC206R
Oct 18, 2009 09:26 AM
newhondaowner29
Jan 11, 2006 08:11 PM
CNSK
Apr 12, 2003 11:13 PM
