00 Civic - Brakes creak
Old Apr 3, 2015 | 08:41 AM
hondatek614's Avatar
Default 00 Civic - Brakes creak
2000 Honda Civic SI -- only makes the creaking noise while braking (usually 15 mph or LESS). Didn't happen (or rare) when cold out. Seems to do it more now that it is getting warm. I thought it might be my pads/rotors because they were nearing time to replace, but after replacing pads/rotors, checking slide pins (and greasing), and checking all bolts/caliper/pistons it is still doing it. It does not make the creaking noise when braking while backing up. Shocks seem to function ok, springs are not cracked (also, does not make a noise when hitting bumps, or if i push down repeatedly on the front end). The ball joints don't appear to have play, and the tie rod also seems ok.
The upper/lower control arms, stabilizer linkages, and sway bar bushings (both sides) were replaced a year ago, and appear to be ok.
Thoughts I have been entertaining are bad bearing, or possibly a strange presentation of bad cv joint??
Last edited by Former User; Apr 3, 2015 at 08:59 AM. Reason: Text clean up after move
Old Apr 3, 2015 | 08:50 AM
Default Re: brakes creak on passenger side of car
of course it could also be the retaining clips...
Old Apr 3, 2015 | 09:01 AM
Former User's Avatar
Default Re: 00 Civic - Brakes creak
Is noise only coming from front brakes?
Did your lubricate all contact points indicated in service manual? What type of grease?
dodt's Avatar
also what brand pads and rotors
Old Apr 3, 2015 | 09:02 AM
see this thread for similar discussion....thoughts?
https://honda-tech.com/honda-civic-d...e-car-3227046/
oem/honda. lubed caliper slides/shims with high temp grease. not my first rodeo so to speak.
Old Apr 3, 2015 | 09:04 AM
and yes, only from front left. dust shield isn't rubbing either...
Old Apr 3, 2015 | 09:14 AM
As you mentioned, try replacing the retainers. If the pads fit a little loosely, there could be vibration and noise.
Old Apr 3, 2015 | 09:19 AM
that is my number one suspicion right now. unfortunately it is raining today (i don't have a garage and am in the baltimore area so my access to tools is limited to pretty basic repairs), so it will have to wait until tomorrow or sunday. the brakes are performing well, and everything else seems fine, so I wouldn't consider it an emergency (haha famous last words). thanks for the responses.
Old Jul 7, 2020 | 05:42 PM
Tomarto's Avatar
Hey, this is an old post but any chance you remember what the fix was? Im having the exact same symptoms.. 😬
me_brewsta
Oct 27, 2016 05:55 PM
J.HU3ZO
10
Feb 3, 2015 06:25 AM
GuitarPunk015
Sep 9, 2009 10:19 AM
Cronousman
Dec 1, 2006 04:23 PM
dj626
Jul 10, 2005 05:31 PM
