93 Accord cranks but no start
Old Apr 1, 2015 | 10:07 PM
sobe911's Avatar
Default 93 Accord cranks but no start
For about a month and a half, my girlfriends Honda accord has had to crank for 5-6sec to turn over, sometimes requiring it to be cranked multiple times. I tried priming the fuel pump by turning the key all the way without starting several times, and that never changes the issues with starting it. She parked it a while ago, and it didn't start in the morning when she was leaving for school, and later in the day it started fine. After that, it was parked and hasn't been able to turn over. I have 2 of my own vehicles, and shes too much of a puss to drive my lifted 88 suburban, and I commute to work, so I need my Subaru. I've replaced the fuel pressure regulator, spark plugs are fine, air filter is clean. Going by fuel air and spark, when I pull the fuel line off the rail and turn the key fuel flows, its getting air, and I see no reason why this would be the spark plugs.
I'm not sure what to hit next. I have a new fuel filter that ill install tomorrow but I doubt it'll make a difference.
I dont really have unlimited funds, and I don't really want to replace the fuel pump (annoying).
advice?
Old Apr 2, 2015 | 01:20 AM
tim73's Avatar
Default Re: 93 Accord cranks but no start
Single poster...
Anyway, if it is indeed getting spark(You said spark plugs are fine, but didnt say how you checked for spark) Then I would suspect the cam position sensor in the distributor. If that's good(Substitute in a known good distributor), then i would check compression.
gurr
Feb 28, 2024 03:51 PM
skinney6
Oct 17, 2012 09:58 PM
SteveL57
Jun 24, 2011 03:59 AM
Lowriderman
Apr 18, 2011 07:10 AM
frzr
Classic Hondas
Jan 15, 2008 09:57 PM
