CA 1995 Acura Integra GS-R Sedan 4 door CLEAN TITLE * SMOG READY
For sale is my Fiance's 1995 Acura Integra GSR GS-R 4door sedan.
-Clean Title
-200,050 original miles
-1.8 liter DOHC VTEC GS-R Original Motor
-5 speed GS-R manual transmission(original) (NO grinds, slipping or "pop outs")
-ABSOLUTELY NO PROBLEMS, NO OVER HEATING, NO LEAKS anywhere under the hood, starts up EVERY TIME.
-All original Oxnard, CA car.
-NEVER smoked in, NEVER had pets inside.
-Passed smog on March 4th, 2015 (Good for 90 days)
-Registration good until September 2015
-Frost white GLOSSY exterior
-3 OEM factory keys from when car was new, 2 master keys, one valet key(opens doors and starts car but DOES NOT open trunk, glovebox or inside levers for gas tank & trunk)
-OEM Factory Spoiler wing with LED brake light
-OEM Factory Alarm with original integra Key fob remote
-OEM factory RARE charcoal gray leather door panels, front & rear seats (seats 3 people in the rear)
leather is in excellent shape on the door panels. few stains on the front and rear seats. driver side has some wear. some parts of leather aren't soft even tho i cleaned & conditioned with Meguiar's leather spray. i rate the seats 7/10 only because of the harness on some area of the front seats and wear on the driver's side.
-Spare tire, factory jack & tools in trunk in event of a flat tire.
-Spacious trunk and rear seats fold down if you need to haul something very long
-Cold A/C recharged on February 13, 2015
-Heater & Defroster
-Sliding & tilt power moonroof/sunroof with sliding sun shade.
-Dark tint of rear windshield and rear side windows (100% legal)
-ABS 4 wheel anti lock braking system, 4 wheel disk brakes.
-Factory lightweight Integra GSR Aluminum alloy wheels with good tires (Kumho all season performance tires in the rear and dunlop sport all season performance tires in the front)
-Power door locks, power windows, and power side mirrors
-Aftermarket Alpine CD stereo deck with Alpine 6-CD changer in the trunk
-Driver & passenger air bags.
-child lock rear doors
-Original INTEGRA charcoal gray floor mats
-Original struts/springs were blown and changed out by previous owner with Premium ($1,399) Neuspeed FULL Coilovers with height adjustability.
-Factory air intake replaced with AEM Cold Air Intake (CALIFORNIA Legal) ($280)
-Original exhaust and catalytic converter were changed out by previous owner with a Magnaflow Catalytic Converter and Genuine Greddy US SPEC Exhaust (looks nice with a polished finish and is NOT obnoxious $540 retail)
Maintenance Done:
-New battery @ 169,972 miles
-Timing belt, water pump, timing belt tensioner, alternator belt & serpentine belt, valve cover gasket as well as valve adjustment, spark plug o-ring gaskets, cam caps & cam seals, distributior O-ring, vtec solenoid gaskets, oil pan gasket all done @180,000 miles by previous owner. All parts used were factory OEM Acura/Honda except the drive belts (the ones on alternator, power steering and a/c)
-NEW Autozone Radiator & OEM Acura thermostat in addition to coolant/antifreeze flush done @188,736 miles by previous owner
-Flywheel resurfaced and NEW OEM replacement clutch, OEM Clutch master cylinder, OEM Clutch slave cylinder done by previous owner @190,815 miles
-New OEM Brake master cylinder and Dot3 brake fluid flush done on 3/10/2015
-New auto zone lifetime warrranty front & rear brake rotors and pads @194,428 miles
-New NGK spark plugs "platinum" & 7mm oem replacement Spark plug wires, OEM Distributor Cap & rotor, OEM Fuel filter & OEM Acura PCV valve @195,629 miles
-Honda Manual Transmission Fluid 2.3quarts drain & refilled @195,741 miles
-Mobil 1 10w-30 Motor oil & oil filter @196,825 miles
-NEW passenger & driver side CV Axles from NAPA @200,000 miles
-Washed by hand, Clay bar'd by hand, Meguiar's Cleaner wax applied & removed by hand, Wolfgang Puck Sealant 3.0 spray applied by hand, and finalized with Meguiar's Hi-tech synthetic wax applied & removed by hand on 3/29/15 @ 200,014 miles.
This is a great car. It was given to my Fiancee by her Uncle. He owned it since 2003 (12 years) and was the second owner. He took great care of it. My Fiancee absolutely LOVES Acura Integras, hence the reason why he finally gave it to her. She was planning on keeping the car (which is why i invested my money for parts/labor) but she is now contemplating selling it to make money for a down payment on a new car to build her credit(women...sigh...). There are no problems with the car, no check engine light, no SRS light, no ABS light. Everything on the car works as it should and is fully functional. This car is in GREAT shape for it's age, bullet proof reliable, handles excellent and is VERY FUN to drive, a "True driver's car" if I do say so myself, which was also quoted by several car magazines when this vehicle came out.
There are several of these Integra Gs-R cars for sale, but few came in the 4door model. The ones out there for sale are either salvaged, modified motors that do not pass smog, or not the original motor/transmission at all. If you are interested come check out the car, test drive it and bring a mechanic if you wish, you will NOT be disappointed.
I am asking $5,800 OR best REASONABLE OFFER. Cash only, sorry no trades.
******Please keep negative comments to yourselves, let's be mature gentlemen/ladies here. Thank you ******
-Clean Title
-Heater & Defroster
Maintenance Done:
Just edit the thread and erase them. But yeah if you lock it they will stay up if you dont erase them.
I Am Si Guy
Jul 30, 2013 10:33 PM
dvot
Feb 17, 2009 06:45 PM
FastASSdb8
Jun 28, 2004 12:41 PM
more pics..
