Help
Hey How's it going,
I just bought an 06 s2k, it was in an accident and got hit in front right side. My problem is that all the lights on the cluster stay on ( vsa, powersteering, abs, "!", brake, airbag ) when you turn it on. Everything works on the cluster except for the rpm. I thought it was something electrical so I checked the wires but they look good. I was thinking maybe that little box by the battery? And my powersteering isn't working either. Any help would b appreciate it.... thanks in advance Jesse
... got the vsa erased the rest are still the same and no rpm working. ..... help plz
Thanks for taking ur time and checking my thread. I went through all the wire harness, fuse box, and wires look good, fuses look good the harness looks good. I went through my abs sensors and the right back side is missing. I've read up that might need to take or to the dealer to get something reset After I put that sensor. I took the car to get it scanned and this is what came up. Any help is appreciated it. Thanks.
☆Fault Codes☆
*12-1: Open Circuit Or High Resistance In Passenger Side Impact AirBag Module.
*15-1: Faulty OPDS Unit Or OPDS Not Initialized.
*16-1: Right Rear Wheel Sensor Failure. " I'm missing That Sensor"
*23-1: Malfunction In Knock Sensor Circuit.
*27-1: Steering Angle Sensor Failure " VSA & "!" Lights"
*61-1: Battery Voltage Failure
*83-1: ECM/PMC Relation Failure.
*84-1: Sensor Logic Failure
☆Fault Codes☆
the wheel speed sensor, even slightly off, is very important to the 06+ it's what helps VSA determine when to trigger traction control protocols
get the wheel speed sensor replaced and then make sure your knuckles and lower control arms aren't bent
shot_them_all
Honda Civic (2001 - 2005)
Dec 6, 2011 04:43 PM
