2001 Honda accord 2.3 coolant temp etc
My coolant temp sensor for the ecu was broken by the previous owner. I tried finding the wires to connect into the sensor and the were cut. I traced back through the wires and found none that were snipped. I need to know where the wires for the coolant temp sensor for my ecu plug into on the ecu. Care failed inspection due to readiness failure so I need to find were the wires connect to
The ECT sensor consist of a Red/Wht wire and a Grn/Blk wire. They should be part of the main wire harness. The Grn/Blk wire (sensor ground) from the PCM connector C pin 18 goes to a 14-P gray junction connector attached to a bracket above the area of the engine oil filter. From the junction connector, the sensor ground splits to other Grn/Blk wires for the TPS, ECT sensor, and IAT sensor. The ECT sensor Red/Wht wire (sensor input to PCM) goes to PCM connector C pin 26.
Junction connectors are terminals grouped together that are connected by the same electrical bus bar. A junction connector can have one or more electrical bus bar. Each bus bar can be used to split/distribute power or ground.
carpenterkyle
Nov 3, 2012 07:45 PM
foress_89
Jan 15, 2008 03:58 PM
