d15b7 swap to d16y7 rough cool idle
Old Mar 29, 2015 | 03:56 PM
jz2518's Avatar
Default d15b7 swap to d16y7 rough cool idle
i swap a d16y7 into a 95 civic that came with a d15b7. i keep everything that came with the d15b7. all i swap out was the block. keep the intake. injector ecu from the b7. the car start right away but have a up and down idle with it is cooled. when it it warms up it idles good. i also get a iac code. i swap it out with a new one and still the same. i doesnt do it whe it is hot. also i discinnected the iac when it is cooled, it doesnt do it. .
Old Mar 30, 2015 | 04:19 AM
Former User's Avatar
Default Re: d15b7 swap to d16y7 rough cool idle
Clean the FITV and bleed the cooling system.
Old Dec 1, 2015 | 12:53 AM
Jahrye's Avatar
I'm doing this exact swap and just wanted to know if anything will be needed.
Can I use the same ECU ?
Old Dec 7, 2015 | 04:10 AM
jz2518's Avatar
I used everything the same. Only thing I did was cut a peice off the power steering bracket. And. Also the brackets that mount the tranny and engine together.
4doorcivic16
Feb 20, 2007 07:14 PM
Acrappyhatch
May 15, 2006 08:53 AM
Touge Tuning
Apr 26, 2006 11:51 AM
Fobtions
May 12, 2003 08:27 PM
