Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Clutch engagement issue when hot
Old Mar 29, 2015 | 05:42 AM
zuni's Avatar
Default Clutch engagement issue when hot
Hey folks, I have a 2004 honda civic si (canadian) so I think that's an ex in the states. Once the car is good and hot the clutch will slip when engaging in first and second. Also, it squeaks when the peddle is released at the end of the motion. Is this a master cylinder issue? Note that it never slips in higher gears and never slips on downshift, or when its cold.
Thanks much for any advice
Old Mar 29, 2015 | 06:24 AM
toyomatt84's Avatar
Sanji
Default Re: Clutch engagement issue when hot
Have you tried bleeding the clutch hydraulics?
Old Mar 29, 2015 | 08:16 AM
zuni's Avatar
Hmm not yet, think that might be the cause? Some other threads also talk about adjusting the clutch pedal.
Old Mar 29, 2015 | 09:51 AM
toyomatt84's Avatar
Sanji
I'd start with bleeding the system. Your hydraulics may have a small air bubble in the line.
blacklabel14
Feb 3, 2011 12:32 PM
crxricer66
Nov 3, 2007 01:44 PM
xunkn0vvnx
Mar 30, 2005 09:23 AM
Perfourmance
Nov 16, 2004 11:08 AM
GSRGuy17
Nov 6, 2002 11:17 AM
