2001 Prelude SH Part out h22a h23a parts available too
I am parting out a salvage title 2001 prelude, it had 148k miles, below is a list of most of the parts and prices, there may be some smaller parts not listed, I will keep the list updated, Located in Livermore CA 925-321-5289
H22a4 Engine Block 97 50mm with girdle no crank and is nearly blank, cylinders good no damage $250 shipped
H22a4 Head With aftermarket valvetrain, guides, spring type lma had even 180psi compression and was hot tanked at a machine shop after being removed, comes with oem cams and gears $250 WITHOUT SHIPPING
H22a4 Head needs new valve train and rocker arms $50 without shipping
H22a H22a4 H23a vtec valve cover blue $60 shipped
1997 Prelude engine Harness obd2 $90 shipped
2001 Prelude Base 5 speed Ecu with immobilizer key and ignition $200 shipped
2001 SH Engine Wire harness $80
AEM Ecu For Prelude w/ Turbo Tune box & aem disc will work with a few bolt on parts temporarily $450
Dsm 550 injectors $150 with wiring
AEM Fuel rail with regulator and guage $125
Power steering pump w hose and overflow tank prelude 1997-2001 $90
Power steering line $40
H22 H22a4 H23 H22a Full Manual Timing Tensioner kit $80
H22a4 oil pump with half shaft $45
Clutch and flywheel with less than 1000 miles no warping no issues with throwout bearing $80 not sure of brand H22a4 Intake manifold Lower half with egr, injectors, fuel rail fits h22a h23a $80
H22a4 Injectors obd2 $45
IAC working no issues $45
H22a4 throttle body with idle control valve, map and tps sensors $50
Oil Filter relocation kit complete with lines moves filter under battery for sh or base better cooling required for a sh supercharger kit $75
Vtec solenoid $40
Alternator for H22a H22a4 H23a prelude 97-01 low mileage $40
Alternator bracket $35 or $60 with alternator
A/c pump with bracket low mileage $40
h22a h23 oil pump with balancer shafts low mileage $40
Front engine mount plate h22a4 h22a h23 $30
1992-1996 h23 intake tube only $30
Kenwood CD player with pocket and radio frame, wire harness and remote $75
Doors silver 97-01 no mirrors no interior handles or panel $100 each
Center console with new shift boot and shift **** 97-01 $45
Seats Black Cloth front and rear 97-01 good shape $
Dashboard perfect condition with passenger airbag $125
Steering wheel with Airbag $40
Door panels interior with switches black $40 each
Passenger door handle with tweeter and switch $30
Passenger Tail Light perfect condition $35
Rear bumper silver great shape no lip 97-01 $70 with silver oem lip $100
Rear bumper support $40
Sunroof complete $100
Stock suspension front and rear 97-01 $100
255 Fuel pump $50
5 lug suspension parts hubs calipers, rotors, control arms, you may be able to convert a 4lug to 5lug with this not sure $150 both sides
Starter $40
sh axles both for $40
H22a4 evap system with charcoal canister and smog sensors $60
Ignition wiring 1997-2001 with antitheft system 2 chips $40
Trunk Cargo mat $3090
Rear speaker Deck with speaker covers $30
2 Hid Kits 1 works bluer color they sometimes turn off when the car goes over bumps turning the headlights on and off restarts it, the other set doesn't light up not sure if its the bulbs or ballasts $40 for both sets non negotiable I wont part out
Silver Trunk with OEM Spoiler and Light, Red Honda badge $150 will not part any of it out
Im located in Livermore CA 925-321-5289
Vtec solenoid $40
255 Fuel pump $50
Starter $40
i meant to say the rear seat covers. it would require pulling the covers off the seats and saves shipping on them. ill pm you my cell number. its easier to get in touch with me that way if needed. I am definately interested in the carpet. i also need front seat covers and rear seat covers. thats without the seats.
customs-25
Apr 1, 2016 07:23 PM
customs-25
Oct 10, 2015 10:29 AM
customs-25
Jul 12, 2012 06:01 PM
customs-25
Mar 8, 2011 11:44 AM
